up ko lang po yung thread.
you can actually make your car move forward by slowly releasing the clutch without stepping on the gas. I do this even on inclines like being stuck in traffic on a bridge. But then I have a 6 cylinder diesel engine ;)Originally Posted by attic_dude
as for your clutch, it's still looks good to me. ma feel mo naman coz during high revs your engine does not give you the usual speed that it does before. of course the clutch system is one of culprit of this, the other being the ignition or the fuel delivery, heck even a bad bearing in the aircon compressor/ power steering pump/alternator could cause also this symtoms.
hmmm, mahirap pala i-diagnose yan. i really think na may prob yung clutch ko e. kasi when i'm moving hirap siya ipasok sa 1st and 2nd gear. parang may grinding noise siya before ma completely engage sa 2nd gear. pero nawawala din.
you mean grinding? yong parang hindi kinagat yung clutch ang gear at mapansin din to kpag hindi mo na full press yung pedal? di kaya clutch talaga prob nyan? try shiftling without shifting the clutch pedal yung ba ang sound?
yes that's what i mean. exactly like that. ano kaya prob dun?Originally Posted by finchy18
baka naman kulang lang sa adjustment yang mga pedals mo. pa check mo muna kung tama pedal freeplay baka nakatukod o kung hindi naman, kulang sa stroke to fully release the clutch.
sir pasingit na lang po ..
paano po kung nasa 3rd or 4 th gear ay hindi smooth ang takbo
(parang kadyot kadyot lang)..
pero sa 1st and 2nd wala naman po ..clutch din po ba ang culprit doon ?
kung bago ang clutch linining mo sir, try mo palitan ng clutch fluid. also check the master for leaks too.Originally Posted by butchokuy
if all's well, most probably the synchronizer na ang culprit.
iyung sa gear oil naman, lagay mo lang 90 grade. 140 malapot na kasi
sabi na nga bah eh.. yung nga ang narinig mo.. kasi sakin I seldom experience that noise only whenOriginally Posted by attic_dude
I change gear without pressing the clutch pedal.. parang ginawa ko automatic.. minsa ang sakit nga sa dibdib kpag narinig ko yan... pero i didnt really mean it na gawin.. fast shift kasi kaya ganun..
anyways, about the prob.. uhmm.. di kaya kulang adjustement yung clutch pedal mo (distance from the floor) what if? kasi hindi kumagat eh.. or sakto ba yong pag change ng gear full press ba talaga yung pedal? wla bang leak yung clutch fluid? check it muna bro.![]()
Originally Posted by afrasay
kya lang pag sa 1st gear or 2nd gear ay walaOriginally Posted by SunTzu
or better i will try to observe my clutch first if its sliding na or what ..
oo nga ,pa check up ko na rin para sure //mahirap pag tumirik pa sa daan ..saan po ba pwede nyo advice na maganda na shop pero di naman taga..around Quezon City lang poOriginally Posted by afrasay
hmmm, interesting, i did notice some leaking sa ilalim ng engine ko. pero at first glance ang isip ko agad is engine oil. pero it could be clutch fluid. is there a way to differentiate the two?Originally Posted by finchy18
suggest ko lagay ka ng newspaper sa ilalim ng car. leave it overnight. then:Originally Posted by attic_dude
kapag black, diesel oil
light to dark brown, gasoline engine oil, and smells a bit like gasoline
kapag reddish, atf
kapag light to dark brown, smells like ****, gear oil
kapag almost clear to brown, brake fluid
kapag clear tapos medyo natutuyo, tubig na iyan. hehehe
