Results 1 to 17 of 17
    hi
    meron squeaky sound when i step on the clutch and
    accelerator. pero pag 1st gear lang. yung sound is parang pag nag oopen ka ng cabinet or door na luma. parang makunat... and mejo matigas clutch and hirap change to 1st gear pag traffic. but there are times na smooth sya as in no problem in shifting. erratic ba.
    a friend told me to have the clutch cable oiled/greased.
    anyways i had the clutch disc, release bearing and pressure plate replaced just a month ago. my ride is 1996 Mazda 323. where do i bring my car? and san pwede magpalagay or pa-change ng gear oil? sana somewhere near marcos hway. :lol:
    and also, theres a "HIssIng" sound on my aircon, pero after awhile mawawala din and then babalik. may interval lang. and i think its coming from under the compartment sa passenger side.
    lastly, parang may water sa loob ng car ko. i dont know where but when i step on the brakes real hard na parang tatalsik na ko palabas ng car :shock: parang may dagat na umaalon ang tunog. parang punong - puno ng tubig.
    TULONG!!!
    WATER SPLASHING AROUND - most probably barado ang drainage ng evaporator mo. The evaporator is usually located in a big box behind the glove compartment. Kapag barado ang drain nito, maiipon ang tubig sa loob ng housing and you will hear water sloshing around. The drain usually leads to the outside of the vehicle kaya nga nagkakawater puddle sa ilalim if you leave the vehicle with the A/C running. Kuha ka alambre then tusukin mo yung drain pipe para maalis ang bara.
    HISSING SOUND - it could mean nothing. It could also mean something's amiss with your expansion valve or your system is not fully filled with refridgerant. Isang taon na yatang ganyan ang tunog ng A/C ko. Hindi ko na pinapansin.
    SQUEAKS - hindi kaya yung return spring lang ng pedal iyon? The one located under the dash and attached directly to the pedals.
    try mo sprayan ng wd40 or something yung spring ng clutch pedal
    OTEP, san yun exactly?
    CoolGal,
    Yung drain ng evaporator? Open the engine bay. Hanapin mo sa passenger side firewall (the back of the engine bay). Usually, it's a black flexible hose that just points downward. Sundutin mo na ng alambre.
    abot ko ba yun? yung parang hose ang susundutin ko? e may tumutulo naman dun e. isip ko baka mataas yung hose tapos yung level nung water di naaabot yun hose kaya d tumutulo... pwede kaya yun? :roll:
    Another thing you might want to look at is the spare wheel compartment.
    Years ago, I drove through knee-high water and had inadvertently filled the spare tire compartment with water. The drain plug had clogged up with dirt, so the water wasn't able to drain out of the back of the car. I was driving around and hearing a lot of water sloshing around in the back whenever I'd accelerate or come to a stop.
    (I could've actually filled the back with goldfish and started a little aquarium! How nice! :D )
    you might want to check your doors. Baka makunat na yung moldings mo or may butas somewhere so pumapasok yung tubig ulan sa doors mo. Ganyan yung problem nung boxtype ko dati. Pag may ulan, para akong may dalang malaking container ng tubig.
    i checked the tire compartment and the doors already. tinusok yung parang maliit na butas sa door kaso wala naman, un sa spare, inangat na yun e basa ng konti pero di naman parang aquarium. :lol:
    i think yung sa hose nga yun na sinasabi ni otep. anyway, natatanggal ba yun? nakita ko na sya e pero d ko pa ginagalaw. mamaya di ko na maibalik ng maayos pag kinalikot ko. :?
    CoolGal,
    CoolGal,
    Tiga-saan ka ba? Baka kung malapit ka lang naman, eh tutulungan na kita. Tutal bakasyon naman at nakatanga lang ako dito sa bahay.
    Yung hose hindi removable. Kaya dapat gumamit ka ng alambre or stiff wire to declog it.
    Cheers.
    sir otep antipolo, along marcos hway. u?
    regarding sa problema sa clutch. ganyan din kasi yung dating sakit nung coroll ko. tanong ko lang, yung hand break mo maganit pag ina-activate? pag oo, yun ang culprit. again pag oo, pag park mo mamayang gabi medyo isagad mo yung pag batak sa hand-break (medyo lang) bukas pakiramdaman mo kung mababasan yung occurrence nung tunog...
    Quote Originally Posted by CoolGal
    Dito po ako bandang U.P. Diliman. Tandang Sora to be exact. Hindi ka ba nagagawi ng Libis o Katipunan? Malapit lang samin 'yun.
    sayang taga proj 8 kaya ako dati 8)
    hey ganyan din yung sa aircon ko. may hissing sound din, parang may sumisingaw. akala ko nung una nanggagaling sa speakers, yun pala sa aircon. pinatignan ko pero di rin naalis. sabi naman nung gumagawa ok pa naman daw yung aircon kaya hinahayaan ko na lang. nilalakasan ko nalang yung radyo para di ko marining.
    since pwede rin clutch dito....tanong lang po ako...
    bakit ganun ung clutch ko...there are times na parang mamatay ung makina pag shift ko while pressing the clutch...pero whenever i push it to the limit (the clutch) bago magshift then gas...okei naman...
    sa adjustment kaya ng clutch un?
    tsaka masyadong matunong ung mga pedals ko...parang if you press it lightly and release "thud" na tunog....
    Feb 2007
    yung clutch ko rin may squeeky sound pag inaapakan... could that be because of the clutch master? at least that is what the guy in the chapchapan told me.. ride ko honda lx 93. sliding na rin clutch ko after a few months to think na nag palit na ako ng bagong clutch disk tsaka flywheel. ok ba magpagawa ng clutch sa shell service bays?
Clutch and Aircon Problem
