Results 241 to 250 of 370
August 9th, 2017 09:19 PM #241
Baka meron sa Toyorama or other sellers of Toyota parts bro.
1000+km na lang pala due na rin yung pickup for atf change. Has anyone seen any Castrol Transmax Multivehicle ATF? The hardware stores and auto supplies I frequent don't have stocks anymore.
August 9th, 2017 09:34 PM #242
toyota ws "world standard". used on 6sp and 8sp new camry.. its low viscosity. mag1 and mitasu have toyota-ws and if you check it also gets dex vi and mercon lv certs
- Apr 2012
- 3,469
August 9th, 2017 09:35 PM #243
August 9th, 2017 09:45 PM #244
Hirap na nga din mag hanap sa mga auto supply and sa ace. Used 12 liters of Mitasu atf on my 09 Santa Fe. IMO, much better na ATF yung Mitasu vs Transmax in my case. Nawala na yung shift shock when downshifting from 4th to 3rd pag inclined. Dati kasi kahit bagong palit ng Transmax meron pa din. Now sa Mitasu about 800kms na natakbo ko nawala na talaga shift shock.
Also medyo overpriced mga labor charges ng ibang shops for dialysis. Most shops ranges sa Congressional/Mindanao ave area charges 1.2k to 1.5k. Sa Exalta banawe 600 lang labor.
August 9th, 2017 10:57 PM #245
- Jul 2016
- 17
August 10th, 2017 12:02 AM #246Re post ko lng po. I just need you inputs mga master:
Good morning mga sir! I just have an inquiry regarding changing ATF. I want to completely change the fluid inside my tranny. I asked a mechanic ng friend ko and sabi niya na no need na daw for a dialysis. Ibaba lng daw oil pan at linisan then refill. Question is pag drop oil pan lang diba hindi natatangal lahat ng fluid lalo na yung nasa Torque Converter? And besides ang alam ko advisable lang eto for manual tranny which is drain and refill (correct me if I'm wrong). Previously manual car ko but now ng palit na ako ng automatic. Really confused. Ano ba mas maganda for a complete change in ATF. Worried na din kasi ako dahil parang may burnt smell na ung fluid the last time I checked. BTW, ride is Mitsu Lancer 98 GLXI AT with InvecsII/sports mode transmission. Really appreciate all feedback and comments. post lang mga sir. maraming salamat and more power sa forum na eto.
August 10th, 2017 12:26 AM #247
drop the pan.. change the transmission filter if meron
BANNED BANNED BANNED
- Sep 2015
- 13,919
August 10th, 2017 12:41 AM #248ito atf "dialysis ang presyo lang dapat 600 ang labor.....
Pag siningil kayo ng 1,500 eh bolahana na yun.
Tapos wag kayo papayag na idillute ng other atf ah.... kasi yung mga nagtitipid eh gagamit muna for flushing ng cheap whiz brand atf.
Example 8 liters capacity
magpapa dialysis 12 to 16 liters gagamtin.... yung mga unang buhos eh yan yun cheap atf para daw maituloak palabas tapos the rest yung talagang atf na.... mali yan.
Kaya hindi ako advice ng dialysis....nangkakwarta lang para madami ka bilhin na atf.... mas ok na yung drain and refil lang....
- Jul 2016
- 17
August 10th, 2017 05:53 AM #249
- Feb 2015
- 174
August 10th, 2017 07:00 AM #250Pano mo po masabi kung need ng dialysis or not.
Casa advised me na need ko daw dialysis. 16 ltrs need for that.
Di nmm na stock kotse ko. MT trans. Mix hiway and city driving. 32.5k km odo reading in 3 yrs. No issues so far. Tia.
Sent from my SM-G532G using Tsikot Forums mobile app
Traffic!
