Page 16 of 19 FirstFirst ... 61213141516171819 LastLast
Results 301 to 320 of 370
    use same type and grade.. im not sure which type though.
    Aug 2017
    #302
    Quote Originally Posted by mmv12 View Post
    hi! ask ko lang baka meron dito naka toyota revo 2000 glx model na nagpalit na ng atf. kasi yung sa amin, nag palit last july 2017 at 113,180 kms (pull down oil pan and throttle body, as per my nephew, as per mekaniko). then this week, pinalitan ulit kasi hindi na mag shift or hirap na mag shift (not sure kung 2nd or 3rd gear). then nung pinalitan, ma itim na ulit yung fluid. kaya ba maitin at hindi mag shift bcoz hindi na drain lahat ng atf? any idea kung ano ang tamang atf (type or grade) para sa revo 2000 at kung ilang liter? i already emailed toyota bicutan, pero wala pa sila reply.
    thanks in advance.
    We used dexron 3 sa revo namin. But if you have the budget, use Toyota's Type-IV. I remember we bought 9 or 10 liters, kasama drain.
    As with the clean oil, strainer should be cleaned, too! Dapat pakita nila sayo na malinis.
    Jul 2012
    #303
    Quote Originally Posted by willownavarro View Post
    thanks willownavarro.
    is dexron 3 a brand or type of an atf? pwede din kaya ibang brand as long as it is type-iv? tama ba understanding ko na yung 9 to 10 liters kasama na dun pinang flushing nyo?
    Aug 2012
    #304
    Quote Originally Posted by raiX View Post
    Guys need advice po..nag pa change atf po kasi ako ng toyota altis 08 10th gen ang nakalagay sa manual atf ws pero ang nilagay ng mechanic atf t-iv..pwede po ba yun?
    ATF WS is not compatible to ATF T-IV. You should use Toyota ATF WS or Multi-vehicle ATF that is compatible to ATF WS. Read the bottle.
    TOYOTA T-IV ? TOYOTA ATF WS ? May i to replace? | ATF, Differential, Trans, Brakes, P/S | Bob Is The Oil Guy
    "Toyota does clearly indicate that THEIR own ATF-WS is NOT compatible with T-IV or Dexron ATF and they recommend only the WS be used in vehicles that call for it. It makes perfect sense that they are not compatible because the additive chemistry is different. This is the same reason you should never add "magic" additives to ATF's to convert one to meet another spec - leave the chemistry work to the reputable ATF manufacturers since they spend enormous amounts of money in engineering and testing of their products."
    Sent from my ASUS_X00DDA using Tapatalk
    Aug 2017
    #305
    Mechanic used this:
    https://cdn.pbrd.co/images/GU7WTZr.png
    Dexron 3 is a type. As for t-iv, use toyota's it cost me 460/L but i think prices differ depending on the toyota branch? I just read it in some comments here in tsikot. Best to compare [but pls check your manual, not sure if t-iv is recommended]
    Yes, kasama flushing. Until malinis na
    Sent from my EVA-L19 using Tsikot Forums mobile app
    Jun 2005
    #306
    Mahal ah. 1200 lang 1 gallon ng ATF T-IV sa toyota makati
    Jul 2012
    #307
    Quote Originally Posted by sirkosero View Post
    Thanks sirkosero. Recently lang ba yan price na yan?
    Sent from my SM-N910U using Tapatalk
    Aug 2017
    #308
    Mura nyan ah. Checked my receipt, 446 pesos pala. Mas mahal pa rin kesa sa price ng Toyota Makati hehe.
    use dex3... toyota typeiv is for newer transmissions.
    Jun 2005
    #310
    Yup. I change ATF almost every other oil change or when i feel like it and get the atf sa casa
    Jul 2012
    #311
    StockEngine, magkaka problem ba kung gagamitin ko yung type iv fluid sa revo 2000 or talaga'ng dexron III lang dapat?
    not sure which dex3 you need but checking some documents type4 is same sa dex3 g/h.. so it might be compatible. but a toyota mechanic can better answer your question better.
    Jul 2012
    #313
    thanks StockEngine. coz i can't find the manual of our revo. it has been long gone.
    Aug 2012
    #314
    I can email you owner's manual of Revo if you need.
    #315
    Before bringing your car for flushing ATF (dialysis process) please take some time to watch this video first.
    Aug 2017
    #316
    Quote Originally Posted by red_one View Post
    Hi, can share w me, too? Sent you PM. Thanks!!
    Jan 2016
    #317
    Thanks Bro Nofalter, best ATF change info share!
    Quote Originally Posted by nofalter View Post
    Jul 2012
    #318
    Thank you red_one. Yes kindly email it to me, please.
    #319
    My Diesel innova has 65k km and I haven't replaced my atf, ever.
    The manual says Toyota Genuine ATF Type-IV. My concern is, do I have to get this exact brand or type. Where do I source this out, are there other legit sellers or casa only? Can you guys recommend a trustworthy and competent shop do this procedure. QC area sana guys. Happy New year!
    toyota type4 is not fully synthetic. go for mag1 fully synthetic multi atf from powertorq congressional.
    have your diff fluid changed also.
    another option is zix performance they have toyota fluid(equivalent) too.
Changing ATF Fluid completely (DIALYSIS PROCESS)
