Page 12 of 19 FirstFirst ... 28910111213141516 ... LastLast
Results 111 to 120 of 370
    Mar 2005
    Baka meron sa Toyorama or other sellers of Toyota parts bro.
    1000+km na lang pala due na rin yung pickup for atf change. Has anyone seen any Castrol Transmax Multivehicle ATF? The hardware stores and auto supplies I frequent don't have stocks anymore.
    Hirap na nga din mag hanap sa mga auto supply and sa ace. Used 12 liters of Mitasu atf on my 09 Santa Fe. IMO, much better na ATF yung Mitasu vs Transmax in my case. Nawala na yung shift shock when downshifting from 4th to 3rd pag inclined. Dati kasi kahit bagong palit ng Transmax meron pa din. Now sa Mitasu about 800kms na natakbo ko nawala na talaga shift shock.
    Also medyo overpriced mga labor charges ng ibang shops for dialysis. Most shops ranges sa Congressional/Mindanao ave area charges 1.2k to 1.5k. Sa Exalta banawe 600 lang labor.
    So its totally different pala from T-IV
    Sent from my LG-H818 using Tapatalk
    toyota ws "world standard". used on 6sp and 8sp new camry.. its low viscosity. mag1 and mitasu have toyota-ws and if you check it also gets dex vi and mercon lv certs
    Apr 2012
    Yung world standard okay pala yon. Heheh
    Mine is Vios 1.5G
    drop the pan.. change the transmission filter if meron
    ito atf "dialysis ang presyo lang dapat 600 ang labor.....
    Pag siningil kayo ng 1,500 eh bolahana na yun.
    Tapos wag kayo papayag na idillute ng other atf ah.... kasi yung mga nagtitipid eh gagamit muna for flushing ng cheap whiz brand atf.
    Example 8 liters capacity
    magpapa dialysis 12 to 16 liters gagamtin.... yung mga unang buhos eh yan yun cheap atf para daw maituloak palabas tapos the rest yung talagang atf na.... mali yan.
    Kaya hindi ako advice ng dialysis....nangkakwarta lang para madami ka bilhin na atf.... mas ok na yung drain and refil lang....
    Mar 2005
    8 Liters lang talaga capacity ng sakin pero consumed 12 liters dahil sa flushing ng system hanggang ma flush out lumang ATF. Better use kung ano talaga ATF mo as flushing. Sa Exalta wala naman sila inoffer sakin na pang flush na cheaper ATF.
    I still like having the pan dropped just to see if there are any metal bits or gunk on the filter. I wouldn't want those things floating around and getting stuck on other parts during dialysis. So I alternate between dropping the pan and getting a dialysis.
    Quote Originally Posted by jmpet626 View Post
    Yun talaga tama kung ano talaga atf eh yun din gamitin for flushing..... Sa exalta maayos kausap yung may-ari mechanico.... Tanungin ka muna if meron ka dala fluids/parts
    Sa fronte yung naghahalo ng ibang atf for flushing.
    sila dalawa sikat sa banawe na mura dialysis...
    Jul 2016
    Salamat sir stock engine. Will this remove the burnt smell? sorry medyo OC hehehe.
    Feb 2015
    Pano mo po masabi kung need ng dialysis or not.
    Casa advised me na need ko daw dialysis. 16 ltrs need for that.
    Di nmm na stock kotse ko. MT trans. Mix hiway and city driving. 32.5k km odo reading in 3 yrs. No issues so far. Tia.
    Sent from my SM-G532G using Tsikot Forums mobile app
Changing ATF Fluid completely (DIALYSIS PROCESS)
