Results 51 to 60 of 370
- Feb 2013
- 10
February 27th, 2013 07:29 PM #51
February 28th, 2013 12:13 AM #52
pag hindi dialysis process ang pag palit atf, it is time consuming, labor intensive and mas dami magagastos na atf at hindi 100% mapapalitan ang lumang atf..
pag manual atf change..
at your first drain and fill 60% pa lang ang bagong atf
at your second drain 80%,
at your third drain 90% pa lang...
every drain that you will do, gagamit ka ng around 6 liters -8 liters of atf (suv mostly) 4-6 pag kotse.. kasi yung majority of the atf is inside the torque converter and cannot be drained through just spill and fill technique,,
so that's 4-6liters per drain X 3 times of draining= 12-18 liters... that would equate to 90% new atf only...
pero if wala talaga nag o-offer ng atf dialysis in your are mam, then bite the bullet...hehehe...
- Feb 2013
- 10
February 28th, 2013 10:05 PM #53Meron po ng atf dialysis dito kaso sobra mahal po eh 8k...pero sa shell po nag atf din ung manual at mura.pede kaya ganun na lang..
March 1st, 2013 12:15 AM #54
- Feb 2013
- 2
March 28th, 2013 06:53 AM #55As with any type; straight, fine how to style curly hair. Having the medium length layered best way to straighten hairstyles. get more information Keratin Hair Therapy | Brazilian Keratin Hair Treatment Step 9Dab or pat how to straighten your hair with gold. Comb through and re-wash your Brazilian Keratin Therapy.
You might feel some of your laser Hair Straightener machine is not set correctly, and it is it a secret. get more information straighten hair In addition to how to style curly hair growth. Your brazilian kerating hair treatments and mucus that helps to improve the appearance of thicker facial brazilian kerating hair treatments. I also desired to have my treatment for hair, clothingandmakeup, in collaboration with Silk2 at this hairy arm.
April 27th, 2013 11:41 PM #56
mga sir any idea kung ilang liters ng atf ang kailangan sa 99 honda civic kapag pinadialysis process ko siya?
April 28th, 2013 01:44 AM #57
April 28th, 2013 03:45 PM #58
sir brainmafia, dito lang po ako manila sampaloc area. plano ko kasi padialysis process yun tranny ko. gusto ko lang sana malaman kung ilang litro ng atf ang kailangan para sa mga civic.
- Jun 2006
- 1,139
April 29th, 2013 07:41 PM #59I did the dialysis process manually, plus i dropped the pan and cleaned the stainles filter mesh and magnets from inside the auto tranny.
I followed the 10 min auto flushing in youtube.
My problems before is that the tranny takes at least 3min to engage in any forward and reverse gears. This happens everytime i shutdown the car for more than an hour. After the manual flushing, it took 3 days aof regular driving for the tranny to go back to normal operation.
Now it works flawlessly. I used 8 liter of ORIGINAL aisin atf. My car is a corolla lovelife with an aisin/wagner tranny.
Bought it in sulit for 220p per liter.
[/URL]
- Aug 2009
- 178
May 28th, 2013 03:26 PM #60any recommended shops within or near makati offering atf dialysis services and how much kaya?
If that's the case, then hindi rin pala lahat ng nakaka-afford sa kanila ay hindi frugal mag-isip...
2021 Toyota Land Cruiser LC300
