Quote Originally Posted by sakurayui View Post
thanks sir sa offer di ako sanay mgdrive kase sa manila,pang dito lang ako laguna lagi drive...ng ask ako sa shell kanina ng atf pala sila saka mura din,pede ba sa shell ako mgpa atf ng hindi dialysis ang process?
pag hindi dialysis process ang pag palit atf, it is time consuming, labor intensive and mas dami magagastos na atf at hindi 100% mapapalitan ang lumang atf..
pag manual atf change..
at your first drain and fill 60% pa lang ang bagong atf
at your second drain 80%,
at your third drain 90% pa lang...
every drain that you will do, gagamit ka ng around 6 liters -8 liters of atf (suv mostly) 4-6 pag kotse.. kasi yung majority of the atf is inside the torque converter and cannot be drained through just spill and fill technique,,
so that's 4-6liters per drain X 3 times of draining= 12-18 liters... that would equate to 90% new atf only...
pero if wala talaga nag o-offer ng atf dialysis in your are mam, then bite the bullet...hehehe...
