Results 1 to 10 of 18
October 30th, 2002 07:09 PM #1
I just got a second hand Buddyclub shiftlight. It doesn't have the cigarette lighter plug socket anymore.
Can anyone please suggest a shop where I can have this installed?
Thanks in advance to your replies 8)
- 62
October 31st, 2002 11:59 AM #2you might want to try sa Fusion R sa may E. Rodriguez. The shop is near the Petron Station, corner tomas morato. I'm sure they know how to do it.
October 31st, 2002 09:56 PM #3
You can have it installed at Group5 along shaw if their mechanic is still working for them. They did a few installations of such before.
October 31st, 2002 11:10 PM #4
he he... hey dexlab! di ko pa nakabit eh... next week siguro pag balik ko manila.
ghosthunter,
thanks man. try ko dun or sa Fusion R. pero diba iba na may ari ng Group 5? iba na pangalan nung shop nila eh.
- 370
November 5th, 2002 07:36 PM #5Supierreman,
The Buddy Club Shift lite doesn't have the lighter plug at all, it attaches directly to the tach output of the distributor or tach input signal behind the gauge cluster.
The type that goes into the lighter plug uses a different signal pickup system.
November 5th, 2002 08:15 PM #6
Auto_Xer,
thanks for the info!...i'll have it installed probably next week. If there are problems consulta ako sa yo
Tsikot Member Rank 4
- 1,842
November 10th, 2002 11:44 PM #7whats so special about this "Buddy club shift light"?
you just attach to the cigarette lighter just like a cellphone charger?
November 11th, 2002 12:15 AM #8
MAXBUWAYA,
Yung nakuha ko kay Dexlab sabi ni Auto_xer yan yung model na wala palang Lighter plug. Yung pivot shift light yung pwede sa lighter plug.
Auto_xer told me na sa Fusion R ko pakabit. Probably this sat siguro
whats so special about this "Buddy club shift light"?...Buti pa SiR mo... lakas! If you want din you can install a shift light in your Weapon car diba. masaya yun!
Rev it up to redline... shiftlite on... shift up... rev it all again... shiftlite...shift up! :P
November 11th, 2002 11:20 AM #9
Originally Posted by MAXBUWAYA
Having a shift light is an advantage when racing because you can do consistent shifts at the proper RPM level you have set.
- 41
When was the last time you changed them? If it's been a while, I suggest following your mechanic's...
Rubber boot question (repair or replace)
