Results 1 to 8 of 8
- Oct 2005
- 33
January 7th, 2006 07:18 PM #1Hi, Does anyone here knows how to modify an isuzu bighorn automatic transmission so that it shifts sooner? like by adding additional switches? they have this power button which makes it shift at a much later rpm, maybe someone here knows how to do the opposite.. thanks.
- Nov 2005
- 61
January 7th, 2006 09:07 PM #2i have a bighorn before and im contented with what it has.
if i may ask why do you need to shift it sooner?
if its diesel and automatic then nothing much we can do on instant acceleration.
a gas variant with manual transmission will solve that acceleration especially during overtaking.
- Oct 2005
- 33
January 7th, 2006 11:52 PM #3well... i just feel that there are times it shifts late.. hehehe its more of an experiment if it will perform better.. ala ako masyado gnagawa ngayon so im fidling and trying to improve it..
- Nov 2005
- 61
January 8th, 2006 10:18 AM #4actually ganun din ang feel ko dati pero nung pinacheck ko sa may automatic transmission shop sa may visayas ave. ok naman pinalubricate ko lang, ganu lang talaga kasi ang kaha nyan bighorn makapal at mabigat compare mo sa trooper nagyon
January 10th, 2006 04:32 PM #5
hmmm, at what rpm does your bighorn shift? we have a bighorn also and i notice the same thing. usually sa 3k rpm siya nag shi shift.
- Oct 2005
- 33
January 10th, 2006 08:45 PM #6mga around 2k kng light driving pero pag medyo nagmamadali, umaabot dn ng 3k.. un nagiging prob k is parang d nya mahanap un tamang gear.. it shifts back and forth when running at high speeds.. or may mga times naman na ayaw nya magshift, parang stuck cya dun.. anyway, i usually pressdown hard then release suddenly then press again softly for it to shift... usually it works, pero may times na ayaw..
- Nov 2005
- 61
January 11th, 2006 06:34 AM #7i think ganun talaga yun. ako i just step on the acc pedal smoothly and constantly kaya normal ang auto switching nya
January 11th, 2006 11:33 AM #8Originally Posted by dinocol
balak ko nga dalin k joseph para ma inspect and hopefully once and for all maayos din yung problem na to.
any diesel a/t engine experts out there, please feel free to comment on our problem, thanks.
As long as it is valid, bring a printed copy. Then, they will ask you to use one of the PCs there...
