Results 1 to 12 of 12
    Apr 2014
    Hello mga sir! I have a Nissan Exalta Grandeur 02 A/T. My problem is minsan hindi nagsshift from 1st gear to second gear yung transmission kahit inaabot na ng 4k yung RPM sa tachometer. Then minsan bigla naman siya magdown-shift then hindi na mag-upshift. Most of the time pati nangayayari siya kapag galing yung kotse sa matagal na pahinga (overnight na di nagamit). Then after I re-start the car, nawawala na ulit yung problem. I had it checked yesterday and hindi daw sliding yung tranny sabi nung mechanic. Ano pa kaya pwedeng maging cause nung problem sa tranny? Salamat!
    Apr 2013
    Baka kailangan mo na magpalit ng transmission fluid.
    Posted via Tsikot Mobile App
    Apr 2014
    Quote Originally Posted by saksidriver View Post
    mga 3x na ako nagpapalit sir simula June, ganun pa din.
    Jan 2003
    Have it scanned muna to isolate possible electrical problems. Anong fluid pala ginamit mo?
    Jul 2014
    Transmission range o tcm
    Tsikot Mobile App
    Apr 2014
    Quote Originally Posted by non-vtec View Post
    yung Castrol Transmax ata yun na Dexron III sir..
    Jan 2003
    Ilan na mileage? Last resort you should do is to try atf dialysis using Nissan Matic D fluid. Otherwise change to surplus na lang.
    Nov 2014
    mga boss gud pm, yung pajero po namin ayaw mag-overdrive kahit naka-on na ang overdrive button, 4m40 po engine 94 pajero JDM. dati pag-ilagay ko sa "snow" ay mag-upshift xa to overdrive kaso ngayon ayaw na talaga, stuck n ako sa 3rd gear, ang tranny b may problema nito or yung electronics/TCM?
    Feb 2009
    before blaming the TCM or PCM, check the inputs first. remember in computer lingo GIGO? in the inputs are not within range, the output will be garbage. check if the MIL is on and/or the O/D light is flashing. the inputs to the transmission control includes but is not limited to : throttle sensor, engine coolant temperature sensor, vehicle speed sensor, the O/D request switch, transmission oil temperature sensor and some other malfunctioning systems of the powertrain or engine control that would place it under "limp" mode.
    Nov 2014
    AT temp lights does blink after a few kms, speedo not working anymore.
    Quote Originally Posted by HULK8030 View Post
    no vehicle speed signal (odo )=no trans shifting ; some transmissions use the trans output sensor, some have separate speed sensor, some use the abs wheel speed sensor. to sum it up you will need a scanner to diagnose the sensor.
    sa case ng NIssan Murano ko CVT 2008 model, hindi rin siya mag upshift at na-stuck sa ist gear. After dinala ko sa Transmission Specialist sa Baguio and had it scanned.The culprit is yung transmission Valve body assembly including wire harness and solenoids. Pinapalitan ko na rin TTC-Transmission Torque Converter.Overall Cost including labor is Php40,000 Petot
Automatic Transmission Will Not Upshift
