Results 1 to 10 of 12
- Apr 2014
- 14
September 16th, 2014 09:59 PM #1Hello mga sir! I have a Nissan Exalta Grandeur 02 A/T. My problem is minsan hindi nagsshift from 1st gear to second gear yung transmission kahit inaabot na ng 4k yung RPM sa tachometer. Then minsan bigla naman siya magdown-shift then hindi na mag-upshift. Most of the time pati nangayayari siya kapag galing yung kotse sa matagal na pahinga (overnight na di nagamit). Then after I re-start the car, nawawala na ulit yung problem. I had it checked yesterday and hindi daw sliding yung tranny sabi nung mechanic. Ano pa kaya pwedeng maging cause nung problem sa tranny? Salamat!
- Apr 2013
- 236
September 16th, 2014 11:34 PM #2Baka kailangan mo na magpalit ng transmission fluid.
Posted via Tsikot Mobile App
- Apr 2014
- 14
September 17th, 2014 12:58 AM #3
September 17th, 2014 02:09 AM #4
Have it scanned muna to isolate possible electrical problems. Anong fluid pala ginamit mo?
- Jul 2014
- 162
- Apr 2014
- 14
September 17th, 2014 02:38 AM #6
September 18th, 2014 03:39 AM #7
Ilan na mileage? Last resort you should do is to try atf dialysis using Nissan Matic D fluid. Otherwise change to surplus na lang.
- Nov 2014
- 3
November 10th, 2014 06:45 PM #8mga boss gud pm, yung pajero po namin ayaw mag-overdrive kahit naka-on na ang overdrive button, 4m40 po engine 94 pajero JDM. dati pag-ilagay ko sa "snow" ay mag-upshift xa to overdrive kaso ngayon ayaw na talaga, stuck n ako sa 3rd gear, ang tranny b may problema nito or yung electronics/TCM?
November 12th, 2014 12:51 PM #9
before blaming the TCM or PCM, check the inputs first. remember in computer lingo GIGO? in the inputs are not within range, the output will be garbage. check if the MIL is on and/or the O/D light is flashing. the inputs to the transmission control includes but is not limited to : throttle sensor, engine coolant temperature sensor, vehicle speed sensor, the O/D request switch, transmission oil temperature sensor and some other malfunctioning systems of the powertrain or engine control that would place it under "limp" mode.
- Nov 2014
- 3
November 13th, 2014 11:36 PM #10
