Page 16 of 22 FirstFirst ... 6121314151617181920 ... LastLast
Results 301 to 320 of 440
    Oct 2008
    #301
    Thanks for the recommendation!
    Jan 2016
    #302
    Good day po. Looking for Nissan teranno transmission especialist nearby Binan, Laguna. . Need to fix. Walang Hawak, nag overheat ang atf at tumitirik makina.... Please mssg me 09194135391.... No calls, I'm on roaming..
    Thanks po..
    Mar 2016
    #303
    Hi! Looking for an AT repair specialist in Makati for our 1989 Nissan Pathfinder. Engine oil is leaking and the seal/gasket seems to need replacement. Would really appreciate the help!
    Called Speedyfix in San Juan today and Migs quoted me 5k sa labor palang pagbaba ng tranny. Ganito po ba talaga yung price? But better parin sana kung meron shop na reliable sa Makati para malapit lang and matutukan ko yung kotse.
    Thank you!
    Mar 2016
    #304
    need po help guys...honda cty typez 2000...ang pinalit na a/t ay kagaya ng sa esi...my problem is ung lagayan nya ng trany support..sa auto ko ay sa front at ung sa esi is sa lower left... pero meron din sya hole sa front ang problema ay maliit ang butas at walang thread...ang tanong ko po ay posible ba or pwede ba idrill un at palakihin ang butas then lagyan ng thread which is size is 14....at saan pwede ipagawa kaya?..salamat po
    Mar 2016
    #305
    Quote Originally Posted by allan1088 View Post
    any idea mga sir
    Apr 2010
    #306
    Help naman: I don't know kung sa Engine or sa Automatic Transmission ang may problema sa kotse ko (Mazda 323). nanginginig yung makina niya on idle...then when shifting to D, may pagkawild yung acceleration niya sa unang gear (pero kapag nasa second gear onwards, smooth na; even sa reverse [R] OK naman yung takbo).
    Mar 2004
    #307
    Have your engine and transmission mounts checked. Replace them with original parts, don't use replacements.
    Aug 2013
    #308
    Good day mga sir. Honda 2002 CRV A/T ang auto ko. Hingi lang ako ng recommendations nyo since wala akong alam sa auto. Nagpaayos kasi ako ng leak ng oil so kinailangan din ibaba yung tranny. Nagpalit din ako ng langis at ATF. Nung binalik na, nagstart na magslide yung tranny ko. Ok takbo sa una, pero kapag uminit nagsaslide sa neutral yung gear. Pero prior to that may jerk na talaga when shifting from park to D. Dinala ko na din sa casa and they recommended for rebuild which they quoted 70k.
    I'm considering na palitan na lang ng surplus pero sa mga nabasa ko dito hindi rin pala sure na magiging ok kapag nagpalit. Gusto ko sana tanungin kung dapat bang iparebuild ko yung tranny or magpalit na lang ng surplus? May mga shops rin ba na nagrerebuild ng tranny? Thanks
    Jun 2016
    #309
    i have a 2000 model honda civic vtec 3 matic transmission, when the tranny failed i had it done at banawe by Dodong at cardiz st., specialty nila transmission, they went to our place early morning, palit ng internals using repair kit, afternoon around 430pm they came back to put the fixed tranny back into the car, cost is 25k, medyo mahal pero at least wala masyado downtime
    dodong 0923808 8076
  10. #310
    Quote Originally Posted by bogsingbagsik View Post
    Contact Jayson Rangel at 09334197528 or 09282342660. Certified Honda Mechanic who specializes in AT rebuild. Prepare mga 35k, he'll use oem Honda repair kit. He does it off hours in his house in Roxas district. He can remove the tranny from your garage, and return it a day or two after.
    Oct 2013
    #311
    For AT troubles, maayos kausap to si Macmac. Dating tao ni Leonard Bulaong. Humiwalay na. Mejo magulo kausap si Bulaong e. and laging puno ung lugar nia sa Cardiz.
    Either maraming customer o madami di naayos.
    09198770031 -MacMac of Banawe.
    Ang negative, wala siyang sariling shop.
    Pwedeng home service. Bili ka na lang ng parts kay Fullness.
    Sent from my SM-J700F using Tsikot Forums mobile app
    #312
    sa south side recommended ko si d & r fast auto repair service sa sucat ave, paranaque
    former honda casa tech ang bosing doon pero they do all kinds of makes & models. minamani na nila actually mga tranny overhauling and the like. nakasabayan ko dati aside from honda vehicles, mga hyundai at isang ford f150. nagulat nga ako pag visit ko last week para palit atf aba'y meron na silang flat bed truck car hauler. business must be doing so well and i'm happy for danny, the owner of the shop
    i'm going back there in the near future to have our monty's atf filter replaced naman
    Aug 2016
    #313
    I need some advice po.
    Yung Auto Tranny po ng Space Wagon ko kakapalit lang po (laman loob that is). Okay naman shifting from 1st gear to 3rd gear (smooth shifting) pero pag naka O/D ON nagrerelease yung gears pag O/D of kumakagat ulit, so lagi po ako naka O/D OFF kahit highway drive. Also pag mejo matagal na siya tumatakbo yung downshift niya negjejerk pero pag kakaandar or pag di pa masyado malayo natatakbo okay lang yung downshift minsan naman okay siya. Anu po kaya possible problem?
    P.S. Surplus po yung ginamit na replacement ng tranny pero yung housing yung original na nakakabit. After ng replacement di pa ako nagpapalit ng ATF, yun parin yung ikinarga ng gumawa po.
    Thanks sa mga magrereply. :-) God Bless.
    Jul 2014
    #314
    Sir anong model ng car mo?
    Sent from my ASUS_T00I using Tsikot Forums mobile app
    Jun 2005
    #315
    Quote Originally Posted by Prince.Mickey View Post
    Nye! Nagpalit ka na ng transmission pero di ka pa nagpalit ng ATF? Maling mali boss.
    Para kang naligo pero sinuot mo pa din yung maduming brief.
    Dapat replace fluid ka dapat. Pinaka basic yan kung may problem ang AT mo...
    Aug 2016
    #316
    Quote Originally Posted by mrjeff View Post
    Sir Mitsubishi Space Wagon po.
    Aug 2016
    #317
    Quote Originally Posted by sirkosero View Post
    Thanks for the response sir, what I meant po is after ng replacement ng tranny bagong ATF yung ginamit, may nabasa kasi ako dito sa thread na need palitan after 1 week yung ATF kasi may metal shavings daw pag bago yung tranny so kailangan daw po palitan after 1 week... tama po ba? :-)
    Mar 2013
    #318
    Quote Originally Posted by bong06 View Post
    boss save the headache, dun mo na patingin sa mechanic ko iyan, HONDA AUTOMATIC TRANSMISSION SPECIALIST FROM QUEZON AVE, MAY SHOP NA SYA SARILI SA CAVITE, SI MEL CASABA... E2 LINK
    Ooops! Page not found
    save the headache pre, i did
    Sir Bong, may shop pa ba sa cavite si Mel Casaba? gumagawa din ba sya ng matic tranny ng toyota avanza? may contact number ba sya?
    Thanks in advance!
    Aug 2010
    #319
    Hi! Pumunta ako sa Bulaong kanina para pa-check ko ang Pajero FM ko. 2010 of August ko pa pala last pinacheck sa kanila. Nagkaruon kase ng leak ang ATF tuwing nakapark. Parang ang nauubos sa isang araw na ATF is 10ml. Ang sabi dito sa isang shop along mindanao avenue is Kailangan na ibaba ang Tranny and prepare daw ako ng 30k. Nagpunta ako kay Mr. Alex Bulaong para i-padiagnose. Sabi niya palit ng O-rings sa tranny kase sigurado siyang sira na daw ang mga seal na yun. 400 each ang isa kay Best colt. Aabutin ako ng mga 5k lahat lahat. Dalhin ko nalang daw pag free na ako kase buong araw daw kailangan para matapos nila. Hindi ko nakita si Leonard kanina kase meron daw ginagawang tranny sa ibang lugar.
    Jun 2008
    #320
    Meron ako Lancer Cedia na lately nag flash yun "N" light. Religiously changed ATF with OEM Mits. Dia SP3. FYI CVT ang transmission nya. Nothing's changed naman sa performance nya and drives normally, except for the flashing "N" light. Pina scan ko for trans error codes. Eto lumabas.. "48-Clutch Sys-2, Turbine SPD. OP. Ano kaya prob nito? Patulong lang kung kanino maganda pa check/fix. TIA sa makaka tulong.
Automatic Transmission Specialist
