Results 1 to 10 of 10
April 25th, 2005 09:14 AM #1
hello,
tanong ko lang kung pano ko kaya maayos yung clutch nung 2002 XUV namin. hirap kasi i-operate nung clutch. masyadong malalim. kelangan todo tapak sa clutch bago mo maipasok sa gear. saka halos todo pa rin ang tapak kung i-engage mo na tumakbo para di mamatay makina.
napalitan na namin ng clutch fluid. di naman matigas yung clutch. yun nga lang malalim.
nai-a-adjust ba yung lalim o babaw ng clutch ng 2002 XUV?
salamat!
April 25th, 2005 10:28 AM #2Originally Posted by amacatan
April 25th, 2005 01:10 PM #4
merong adjusting nut yun sa ilalim ng clutch pedal... ewan lang kung maso-solve yung by adjusting that. hanapin mo sa manual, naka describe dun kung pano iadjust yung adjusting nut. kung di pa rin makuha, baka nga palitin na yung clutch repair kit. spring at goma lang naman yun.. mura lang. just go to your nearest casa for replacement.
April 25th, 2005 01:17 PM #5
I dont think kaya na ng adjustment yan, siguro laspag na release bearing and PP mo, clutch driver ka ba?
Ako oo kaya bilis malaspag clutch ko hehe
April 25th, 2005 07:04 PM #7Originally Posted by theveed
baka makuha pa sa adjustment. mga quarter inch din yung maiaadjust mo with the clutch adjusting nut. malaking bagay din yun.
saka di naman nya sinabing dumudulas na clutch nya e... so dehins pa yun. pero kung yung PP and release bearing nga ang problem... nakow...
April 26th, 2005 05:29 PM #9
makikisali na rin po....
ung xtrm ko naman po matigas ang clutch. anu po kaya ang sira?
tnx in advance.
April 27th, 2005 11:47 AM #10
amacatan: Baka nasa master cylinder lang yan. Repair kit, brake/clutch fluid and DYI will cost you less than P500 and 2 hrs of your time.
For the Toyota products its likely to be the case for most of their products per the service...
Wheel Alignment
