I have a couple of ways to approach this.
First, I slow down, step on the brake and release it just before hitting the hump. Approach speed is dependent on the contour of the hump....Then as soon as the front tyres are over the hump, then I switch gear to 1st or 2nd, depending on the vehicle speed.
Second, I slow down, step on the brake and switch gear to 1st or 2nd, depending on the contour of the hump and after which I release the clutch and the brake just before hitting the hump.
A/T - just hit the hump at the proper speed (Again, release the brake just before hitting the hump so that the impact is on the front tyres, not the suspension)....
Here in BF Paranaque, I use mostly the second approach, and 2nd gear because the contour of the humps is not that steep.... Else, if you appear to stop suddenly, the cars at the back may hit you.....
8505:bat:
depende sa humps at sa arangkada mo at sa traffic,
highest gear for me with a hump is third gear, nag first gear lang ako if from full stop,
2nd gear since may momentum pa yung pababa ng humps to push the car. minsan 3rd, pero alalay ako sa clutch para di mamatayan ng makina.
