1.3J
1.3E
1.3G
1.5G
1.5 XX
1.5S
1.5SE
I don't own a VIOS.
Time to replace with superman models. Is that a buy-back or leasing unit, hope its insured?
Kulang sa tulog.[emoji42][emoji42][emoji42]
So that's why the passenger side is wrecked. The collision with the pole and subsequent excursion to soil and turf must have killed his speed before he hit the wall at low speed. Buo pa kasi yung metal front bumper bar.
Doesn't look too bad all things considered. Really lucky fellow.
Airbag and seatbelt saved him. I wonder if airbag was a replaced/recalled unit, iirc up to 2011 vios NCP models are affected by faulty Takata airbags.
good eve!
need help po, naiwan ko kasi yung key remote sa loob ng car and nag auto-lock sya.
di ko na ngayon mabukasan. nasa akin pa naman yung spare key kaso walang remote yun. natatakot ako buksan kasi baka mag-alarm and hindi ko alam pano i-disarm. baka maistorbo mga kapit bahay kapag nag alarm, gabi na kasi.
pano po ba i-disarm yung alarm?
i have the vios 1.3e, 3rd gen. stock alarm lang gamit ko, TVSS.
thanks po sa tutulong!
EDIT: nag backread ako,tama ba yung on/off yung accessory para ma disarm?
use your spare key to open the door.
then, immediately grab the key with alarm remote that you left inside, and press the silence or dis-arm button, to avoid escandalo.
seriously, po. ganyan lang yan.
and no, the car won't explode a few seconds after the alarm blares out.
i don't know with your car, but in some cars, the alarm automatically shuts down, when you open the lock with the key.
mga bros, may alam kayo na rubber boot lang mabibili like this one?
sa toyorama kasi repair kit lang meron eh. thanks!
try banawe.
something wear-and-tear like that should be easy to find.
errr... para san po yan?
at ano pa ang kasama ng repair kit na dapat bilhin para makuha ang boots?
Sa brake caliper ba yan boot na yan? Alam ko repair kit lang yan meron
Sent from my MI MAX 2 using Tapatalk
Bili ka lang ng local na repair kit kamo. Yung mura lang tapos kunin mo lang yung boot. Ganun ginawa ko dati
sounds like a plan hehehe
try ko bro thanks sa tip ..
i guess heeding dr.d's advice, tignan ko muna quality ng rubber; if not so OK baka orig kit nalang nga siguro.
ok pa naman bro, na-OOC lang ako sa bloated rubber hehehe
Hi mga paps,
Tanong ko lang if pwede ba i-upgrade yung tires from 185/60r15 to 185/65r15 ? Reason is sumasayad kasi yung front bumper sa garahe kapag palabas, need lang ng konting ground clearance... Sakto lang kaya xia at hindi tatama sa fender even fully loaded yung rear ? My car is Gen 2 Vios.
Thanks !
