View Poll Results: What's the variant of your Vios?
Voters
604. You may not vote on this poll
  • 1.3J
    86 14.24%
  • 1.3E
    280 46.36%
  • 1.3G
    57 9.44%
  • 1.5G
    118 19.54%
  • 1.5 XX
    4 0.66%
  • 1.5S
    2 0.33%
  • 1.5SE
    5 0.83%
  • I don't own a VIOS.
    52 8.61%
Page 442 of 580 FirstFirst ... 342392432438439440441442443444445446452492542 ... LastLast
Results 8,821 to 8,840 of 11582
    #8821
    Sir kimbon, may hole ba na sabitan?
    Posted via Tsikot Mobile App
    #8822
    ^^^funny, pagclick ng link aircon compressor lumalabas. Pagcopy paste, page not found.
    May error ba ulit tsikot?
    Oct 2008
    #8823
    Ok naman sa akin. Using open in new tab.
    #8824
    Mga Boss, sino dito gumagamit ng Nitrogen air sa gulong?
    Question is if I used Nitrogen, is it okay to add ordinary air using the compressor in gas station? Any effect/bad result?
    What is the ideal pressure when you use Nitrogen?
    Aug 2012
    #8825
    Mga sir sino dito naka obd2 scanner? ano normal coolant temp niyo city driving? kasi sa akin 96 deg cel nagoon ung radiator fan eh w/o aircon
    #8826
    Quote Originally Posted by donskie_0728 View Post
    Okay lang nitrogen at oxygen magmix. No issue.
    Pero may gastos pa nitrogen, tapos kung hahaluan mo ng oxygen, mababalewala ung purpose kung bakit ka nagpanitro.
    Imho, kung may gas station na on the way mo palagi, stay with oxygen. Ang important naman eh correct ang tire pressure mo. Pero kung tamad ka oahangin ng gulong mo, better magnitrogen.
    The ideal pressure of nitro is same with oxygen.
    Ang difference lang mas malaki molecular structure ng nitro kaya mas matagal lumambot ang normally gamit sa pangarera para hindi magiverheat gulong kasi ung normal temp niya malamig at since mas malaki molecule, mas mahirap painitin compared sa oxygen.
    Sa daily drive, for me di naman ramdam difference as long as you always check your pressure.
    #8827
    Quote Originally Posted by brainmafia_310 View Post
    Thanks Bro BM. Mejo madalas kasi long drive ko and province pa kaya madami lubak nadadaanan. Okay na din nitrogen atleast nasubukan and mejo maganda nga ride hindi masyado matagtag. And sa init dito sa norte and more on long drive better choice I think basrd on yout inputs.
    Sent from my HTC One X using Tapatalk
    #8828
    there's this article in the internet that concludes, "the advantage of nitrogen in tires is so minimal in normal driving, that it would probably be cost-effective only if it were given away for free...".
    #8829
    ^^^similarly, nitro in most tire shops are not that pure compared to race team equipment.
    By the way sir donskie, di dapat magbago ride quality, sorry and sad to say that it is a placebo effect - because 32psi is still 32psi, nitro, helium or oxygen man yan.
    Hth.
    Sep 2013
    #8830
    Nope, walang hole ito. bat need mo ba may hole? may spikes sa reverse side ng matting kaya once nailagay na sa carpet ay secured na ito...
    #8831
    ^^^may hole kasi at pagwala aangat yung bandang dulo. Pero, taning ko na lang kung pede pabutasan. Seak na swak din yung kulay para magkaaccent ako sa loob ng vios
    Sep 2013
    #8832
    ^ * brainmafia_310- sakin di naman umaangat ang dulo. try mo muna kayang gamitin na walng hole then later optional na lang ipabutas mo. BTW may other colors pa yan like gray & black....
    Jun 2005
    #8833
    Quote Originally Posted by chard23 View Post
    thats normal. im using obd to monitor the temp in a gen1, (1.5l) gen2 and gen3 (both 1.3l). 96 deg talaga ang on ng fan. around 86 deg naman kapag may aircon.
    Sent from my Thrill 430x using Tapatalk 2
    #8834
    Yung mga interesado magpalit ng goma diyan, papakawalan ko na yung gulong ng spare tire ko na brandew. 185 60 r15 yokohama aspec db e70b, 380p sa suking tindahan, selling it at 3k na lang. Yan ang presyong orig sa baba.
    Aug 2012
    #8835
    Quote Originally Posted by sirkosero View Post
    Thanks sir. umaabot ba sayo ng 96 deg kahit naka aircon pag gabi? dahil kasi malamig na sa loob kaya di na palagi nabukas compressor resulting sa mataas na coolant temp
    Jul 2010
    #8836
    Mga ka-vios may idea naba kayo kung paano ikakabit yung new plates with new one way screw? Kung napanood niyo yung video kung paano ikabit yung new plate, may nut na kailangan ikabit sa likurang dulo ng screw which is likod narin ng bumper. Kaka-check ko lang kanina at wala akong makitang space para ilusot ang kamay at ikabit ang nut sa dulo ng screw. Radiator na agad yung nasa likod ng bumper. Mukhang tanggal bumper o kung anu man ang tanging paraan para maikabit itong bagong plate sa vios. O baka meron na sa inyong nakapag-check kung may ibang pang way.
    #8837
    Quote Originally Posted by kimbon View Post
    yung vios ko kasi sir may hook na, baka yung sa inyo po wala apng hook.
    Oct 2008
    #8838
    Quote Originally Posted by noone09 View Post
    wow mukang hassle ah. what if ordinary nuts lang ilagay? sisitahin kaya?
    Oct 2008
    #8839
    Guys, ano ba tamang pag off ng engine? Kasi pag dumating ako sa destination ko, naririnig ko pa minsan na may fan na umaandar then mag o-off then aandar. ok lang ba patayin yung makina pag nasa process pa nung cooling yung fan na yun?
    #8840
    ^^^ yup, should not be an issue.
Toyota Vios Owners & Discussions Thread
