View Poll Results: What's the variant of your Vios?
Voters
599. You may not vote on this poll
  • 1.3J
    86 14.36%
  • 1.3E
    279 46.58%
  • 1.3G
    56 9.35%
  • 1.5G
    117 19.53%
  • 1.5 XX
    4 0.67%
  • 1.5S
    2 0.33%
  • 1.5SE
    5 0.83%
  • I don't own a VIOS.
    50 8.35%
Page 1074 of 1155 FirstFirst ... 9741024106410701071107210731074107510761077107810841124 ... LastLast
Results 10,731 to 10,740 of 11542
    Apr 2012
    #10731
    Fuel and air...
    Air filter is clean? Throttle body clean? A few philip screws to loosen...
    Cleaned air filter. Last 2 months ago i brought my vios sa Servitek, same symptoms pero not dying ang engine. They loose the connection between the intake and dunsa throttle body nga yata then they started the card at tinggal yung hose from air filter. Tapos inisprayhan ng carb cleaner and ni rebolusyon ng 5k rpm, umokey na ulit noon
    Sent from my LG-H818 using Tapatalk
    Apr 2012
    #10732
    Quote Originally Posted by sirkosero View Post
    Linis muna throttle body + maf
    Then remove battery
    Where is maf located?
    Jun 2005
    #10733
    ^its the one on top of the air cleaner box
    Jun 2005
    #10734
    Sa officemate ko, parehong pareho kayo ng nangyari.
    Pero after dismantling the throttle body from the engine and a thorough clean,okay na uli.
    Minsan di kaya ng bast spray lang kasi naiiwan sa loob na residue na parang kulangot.
    Yes the spray cannot reach the backside of the butterfly valve.
    Kahit malinis ang air filter meron parin nakakapasok... weird lng
    Jan 2017
    #10736
    first time car owner po mga sir...itatanong ko lang po sana kung ilang liter po ba ang engine saka transmission oil ng toyota vios 2006 model 1.5g a/t..gusto ko po sana na ako ang mag-change oil nito tulad ng ginagwa ko sa motor ko...wala po kasi manual eto eh...wala rin ako mahanap sa google na spec sheet or manual para sa model na eto...
    thanks
    Oct 2013
    #10737
    its because of the PCV that bypasses the air filter, don't forget to check/clean it...
    Feb 2015
    #10738
    Hi guys! Nag bukas check engine light ko kamakailan, nagpabasa ko sa Bosch shop, error code para sa VVT solenoid lumabas. Nag simula to 4 weeks ago pero nasakto sa change oil ko nung panahon na yun, pagkachange oil ko nun, wala pang 1km na takbo ko nawala CEL. Pero bamalik siya not long after, 3 week later. Ngayon kakapalit ko lang sakanya, did it myself 3.5k yung pyesa galing sa banawe. May napansin lang ako sa Oil Control Valve mismo nung pinalitan ko, parang may nakita akong opening na parang dahil may pirasong nagcrack-off, inaattach ko pics, di ko alam kung ganyan talaga itsura nung OCV pag tinanggal yung solenoid.
    Salamat mga sir!
    Attached Thumbnails Attached Thumbnails 16121743_10208160820527508_434657184_o.jpg   16122041_10208160819967494_792312263_o.jpg   16122110_10208160820567509_184112758_o.jpg   16145789_10208160820007495_1734479133_o.jpg
    Feb 2015
    #10739
    Sorry for double post, sira ata edit ng tsikot website:
    2NZ engine pala, 2006 vios 1.3E.
    Inisip ko hindi ko naman sya nasira nung inalis ko solenoid dahil nasa likod naman yang part na yan ng solenoid, ang hila ko palabas.
    Thanks again!
    #10740
    Quote Originally Posted by cyberjunkie View Post
    thanks
    3.7L for engine oil
    Pero sabi sakin 3.5L since pag change oil may natitira talaga sa loob. True enough when i poured exactly 3.7L lampas na sa full.
    Quote Originally Posted by patriots21 View Post
    Thanks again!
    Meron ako obd2 scanner, pasig maybunga lang ako and araneta cubao on weekends. Pwede natin scan yan. Kung 443 error yan, dali lang gawin.
    ninjababez online
Toyota Vios Owners & Discussions Thread
