View Poll Results: What's the variant of your Vios?
- Voters
- 599. You may not vote on this poll
1.3J
86 14.36% -
1.3E
279 46.58% -
1.3G
56 9.35% -
1.5G
117 19.53% -
1.5 XX
4 0.67% -
1.5S
2 0.33% -
1.5SE
5 0.83% -
I don't own a VIOS.
50 8.35%
Results 10,711 to 10,720 of 11542
- Dec 2016
- 5
December 5th, 2016 11:25 PM #10711hello guys, im planning to replace the suspension of my vios 2011 from stock. i find the ride unconfortable na dahil sobrang tagtag na at maalog. sobrang ramdam na rin ung vibrations sa loob due to uneven or gaspang of roads. this was also the suggestion of the mechanic that i talked to. now i'm asking if you can recommend for specific brands/models that would best fit especially for comfort. ok ba ung kyb? i heard ito daw usually gamit ng mga jap car vendors.
TIA!
Sent from my SM-A300F using Tapatalk
December 6th, 2016 12:06 AM #10712
- Dec 2016
- 5
December 6th, 2016 12:25 AM #10713thanks monty, btw hm ung kyb for 1 set? ngpalit ka rin ba ng shock mounts?
Ngtanong ako kahapon dun sa service center na pinuntahan ko ang quote sakin 4300php x2 front, 2600php x2 rear tapos ung mounting is 1300php each. Di ko sure kung worth it na un or baka overpriced?
December 6th, 2016 01:51 AM #10714
- Jun 2005
- 3,774
December 6th, 2016 08:31 AM #10715Yung sa gen1 vios, 2300 ang shocks sa harap x2
1200 naman ang shocks sa likod x2
Pareho KYB ang brand. Binili ko sa pasay taft. Tapos 750 ang shock mount.
- Dec 2016
- 5
December 6th, 2016 09:50 PM #10716
- Dec 2016
- 5
December 6th, 2016 10:04 PM #10717
December 11th, 2016 02:02 AM #10718
meron po ba ditong naka experience ng parang rattling sound kapag humihinto ang sasayan... sa may bandang harapan... parang plastic lang ung tunog sobrang hina... pero nakakairita kc parang may loose bolt na hindi ko maintindihan... ung tunog nya ay parang sirang electric fan na tumutunog pag gumagalaw pakaliwa at pakanan... thanks in advance...
Sent from my HUAWEI KII-L22 using Tsikot Forums mobile app
December 11th, 2016 02:20 AM #10719
When was the last nut and bolt tightening done? Model year of your vehicle? Brake shims maybe dislodge or a small stone is stuck on you brake caliper assembly...
- May 2013
- 140
December 11th, 2016 11:25 AM #10720May bayad ba pa-ECU scan sa casa? Pag nagtanong ako sa kanila palagi ang sagot diagnostic. Kaso may bayad.
Sent from my SM-J700H using Tapatalk
A 70/30 water to coolant mix may improve cooling efficiency but that's at the cost of less...
Coolant...
