Page 143 of 145 FirstFirst ... 4393133139140141142143144145 LastLast
Results 1,421 to 1,430 of 1447
    Nov 2017
    #1421
    Quote Originally Posted by Chi-SR View Post
    Mga sir, planning to replace yung front and rear shocks for RevoSR, KYB yung plano ko ipalit. Question, may mga variants sya and honestly wala ako idea sa difference nung mga variants aside sa price of one variant is higher than the other variant. para sa RevoSR anong type/variant ng shocks ba and dapat or recommended na ilagay. and if meron din kayo marecommend na other brand aside sa KYB na within price range at quality.
    Thanks
    Reading around the gas type(Excel-G/Gas-adjust) mas okay daw pag palaging kargado ung sasakyan pero masmatagtag pag walang laman at mahal kesa ung oil type (kyb premium).
    Jan 2017
    #1422
    Quote Originally Posted by LOLZ View Post
    Salamat sir
    Apr 2021
    #1423
    mga sir baka may marecommend kayo na pwedeng pag pa check up ng transmission for REVO-SR(automatic) south area sana.
    salamat
    Ganito din inquiry ko sir, san sa south area may maayos na talyer.
    Owner of 2000 revo sr m/t gasoline. Ang nangyari kasi sa akin, ayaw na magregister yung speedometer. Kapapalit lang ng cable, pag ginagalaw yung cable, pumipitik naman yung gauge kaso pag kinabit na, stuck na po sa zero. Nung hindi pa pinapalitan yung cable, stuck yung gauge up until i reach speed of 60.
    May mga nahingan na ako ng opinions, sabi nila may papalitan daw sa transmission, kaso ayaw ko ipagalaw yung transmission po neto sa basta bastang talyer lang. May nakaexperience na po ba ng ganitong situation dito?
    Sana may mashare kayong talyer na integrity wise eh maayos. Salamat po in advance.
    Dec 2019
    #1424
    Quote Originally Posted by Dadogisdacat View Post
    Try sa cruiser autoparts sa may sucat near evacom. diyan ako nag pakabit ng speedometer cable ng glx gas m/t ko early last year.
    ganyan din issue ko rin dati lagi naman siyan stuck sa 0 yung speedometer needle, tapos pag nasa SLEX na biglang iilaw ang engine light pag natakbo ng mga 80-100kph. nawala naman yung engine light nung pinalitan. pero medyo bouncy na yung speedometer needle pag umaandar na...
    Apr 2021
    #1425
    Salamat will try sir. Sabi din ng isang pinagtanungan ko, sa rapide, yung gear daw sa may transmission ang pudpod na kaya pag high speed lang daw kumakagat. Plastic lang daw. Sadly wala sila ng part na yun.
    Apr 2021
    #1426
    Di naman nailaw yung engine light ko, yung speedometer lang talaga ang di nagalaw even yung numbers sa mileage din na rin nagalaw. Pinagtataka ko lang is after mapalitan ng cable maski high speed di na rin nagalaw.
    Sana may parts sila. Puntahan ko yung sinabi niyo. Was thinking sa kasa na kasi baka wala din sila parts na na kailangan kaso mahal dun for sure
    Nov 2017
    #1427
    Walang stock atm pero may listing sa lazada nun speedogear baka magkaron ulit ng stocks
    Toyota Revo 1.8 7KE,FX 7K Speedometer Gear 33482-2945 | Lazada PH
    Jan 2017
    #1428
    Mga sirs, ok lang ba gumamit ng Toyota ATF T-IV para sa REVO SR? Dexron III (Toyata ATF T-III) kasi ang nakalagay sa manual. Baka may recommended din na magandang replacement brand ng ATF.
    salamat
    Jun 2005
    #1429
    Pwede naman. Afaik T-IV is dex3 equivalent.
    Or bili ka na lang dex3 talaga. Mas mura pa sa autosupply.
    salamat
    Sent from my MI MAX 2 using Tsikot Forums mobile app
    Jan 2008
    #1430
    stick to what is the original requirement.. mahirap pag palit palitin lalo na yan ATF ng transmission..
Toyota Revo Owner's Club Details
