Results 9,951 to 9,960 of 15485
- 54,258
February 12th, 2015 02:54 PM #9951best to stick to stock.
baka matunaw ang housing...
besides, who told you your brake lights were dim?
- 54,258
February 12th, 2015 02:58 PM #9952una, bakit ka nakukulangan na ng liwanag? may problema ba ang mata nyo? sa duktor po kayo pumunta.
baka naman, lumalabo na ang plastic lens ng headlight housing.. try re-surfacing the outside with plastic cleaner. kung sa loob naman, someone might know who can do it..
but if you are able, replace the assembly..
my concern with higher wattage lamps, is that the housing and/or socket might melt.
February 12th, 2015 03:05 PM #9953
di naman po for preference for safety din pag grabe buhos ulan halos di na makita brake light...
mejo malabo na po ang mata at nasa 60++ na po ako kaya hirap na po sa maneho sa gabi. pero ikokonsider ko po yan mga suhestiyon niyo po
- 54,258
February 12th, 2015 04:48 PM #9954visibility is poor in strong rains.. that is why we should all slow down in them. increasing bulb wattage may not be a bright idea, because...
they may become blinding under ordinary conditions..
we all know who these are.. nakaka-silaw kapag nag-brake..
and sir, if you think your vision is worse now because of age, perhaps you should consider retiring your driver's license... for the sake of the rest of us!
February 12th, 2015 06:20 PM #9955
ok lang ba pagbigyan mo muna ako palitan ung bumbilya? hehehehehe
susubukan ko muna ung nightbreaker kasi madami din un ang suggestion. di sila nagsuggest na wag na magmaneho hehehehe
- 54,258
February 12th, 2015 07:11 PM #9956
February 12th, 2015 10:11 PM #9957
- 54,258
February 13th, 2015 09:37 AM #9958
February 13th, 2015 12:17 PM #9959
- Nov 2009
- 38
February 13th, 2015 02:17 PM #9960Mas makakatulong ata boss to remove tint and wear corrective glasses to resolve your problem regarding light
Was an osram nightbreaker, nightbreaker plus, philips night vision user before on medium tint. may improvement kaso minimal. And wala akong swerte sa bulbs na to, pundi agad ang low beam in 12-14 months.
this time around, i had hid projector retrofits. the difference was very Huge.
If you really want better light output, this is the way to go. Save up and invest. Imho
The CHAdeMO plug is definitely a concern. And yes, you are potentially purchasing old tech. In...
2021 Nissan Leaf
