Results 7,981 to 7,990 of 15351
- Oct 2013
- 1,181
- Mar 2013
- 31
January 9th, 2014 07:55 PM #7982so, kung may relay na ang horn for toyota innova 2013, it is safe to install bosch europa silver sa innova ko na parang plug and play lang mga sir (no additional relay ) ?
- 52,890
January 10th, 2014 12:39 AM #7983
- Nov 2012
- 33
January 10th, 2014 06:11 AM #7984hope this will help. just change the fog light with horn.. i also use gauge 14 wires kasi sabi nila baka daw masunog yung stock or minsan daw paos yung busina pag stock.
What i did is disconnect the wire from the stock horn.. tapos yung stock wire connect to relay no. 85. then the rest wire gauge 14 na gamit ko. Yung wire going to + terminal may 20 amp fuse din ako nilagay to make sure.. yung relay binalutan ko nlang ng electrical tape and hide it somewhere na hindi mababasa. hope this help.
- Oct 2013
- 1,181
January 10th, 2014 06:31 AM #7985
- Oct 2013
- 1,181
January 10th, 2014 06:48 AM #7986
- Mar 2013
- 31
January 10th, 2014 09:58 AM #7987sir kasya naman po yung europa sa grill. ang sabi sakin. Ok lang daw po na parang plug and play nalang daw po yung horn sa mga bagong labas na innova daw po. so simple wire plug in nalang po ginawa ko. pano po ba magpost ng pic dito? para po mapost ko po yung ginawa ko. thanks sa lahat ng mga sumagot sa tanong ko.
- Jun 2006
- 1,139
January 10th, 2014 11:07 AM #7988Installed my europa silver on the bottom cross bar of the chassis. Meron 2 butas don, sakto sa turnilyo. No need to drill holes.
Pero i installed a separate relay, mura lang naman and it preserves the orig end connector. Para pag me warranty claim ako, pedd ko tanggalin kagad europa and reconnect the orig horns.
How sure are we that the orig relay will handle the amp rating of the new horn?
- Oct 2013
- 1,181
January 10th, 2014 02:22 PM #7989Don't worry about the relay, worry about the fuse.
Kung pumutok ang fuse, ibig sabihin mataas ang ampere rating ng horn, check the schematic, pang Innova ang mga yan.
January 10th, 2014 08:06 PM #7990
U need to intall a separate harness if u upgrade to a louder horn. Yung stock horn wiring is too thin. Stock fuse will also not be able the higher current.
probably not... yet, siguro. too many unknowns, yet. but if the manufacturer would offer it to...
MG 3 (3rd Gen)
