Page 198 of 775 FirstFirst ... 98148188194195196197198199200201202208248298 ... LastLast
Results 3,941 to 3,960 of 15487
    #3941
    Also noticed the apparent weakness in the rear hydraulics door stay supplied with Toyota Fortuner or Innova. On my Fort, Casa replaced a set right before warranty expired and after almost three years now, this set is beginning to act up a bit.
    Oh well,- underrated kasi ang mga iyan, bro.
    Compared with our 14-year old van,- hangga ngayon walang problema sa rear door kapag binuksan,......
    16.5K:weathermanf3:
    Aug 2006
    #3942
    Pag mahirap buksan/i-angat rear door, sira na ang isang hydraulic stay/lifter. Isolation ginagawa sa casa tinatanggal muna isang side then test lifting the door.
    Sep 2011
    #3943
    Mar 2011
    #3944
    When opening the hydraulic rear door, I noticed that it doesn't open fully as it use to be. I would say it is 90% open and then I had to push it slightly to make it fully open. Something is wrong with the hydraulics perhaps? Any DIY for this or should i have it repaired?
    baka eto kasagutan mo jan bro.....meron ako..hehehe..
    Jun 2008
    #3945
    We intend to purchase an Innova E model with auto transmission.
    Which is better the diesel D4D or the Gasoline-fed VVTi variant?
    Is the Toyota D4D engine still suffering from choking and hard start problem?
    TIA
    May 2005
    #3946
    Quote Originally Posted by auto_fanatic View Post
    TIA
    Diesel cost Php 60,000 more than a similarly equipped gas powered.
    Depends on your needs. If you easily cover 10,000 kms + annually, better go with the diesel.
    Jan 2011
    #3947
    TIA
    For long term, get a VVTI. D4D, diesel engines will need a lot of maintenance after 80-100K. calibration, timing belt, SCV, fuel pump. If you have a driver, go with D4D. If you're the one driving, go with VVTI. VVTi has no timing belt and no worry for dirty fuel(no need to change fuel filter frequently). But if you do mind the price of gasoline and use more than 10K per year, go with the D4D. D4D has timing belt, needs to have clean diesel fuel, change fuel filter every 10K, high resale value. VVTI has timing chain, can go 10K oil change with synthetic, low resale value. Our A/T gas gets 6-7 KpL makati, ortigas city driving. NLEX going to clark, SLEX going to tagaytay 10-12 KpL. No major problems so far after almost 3 years and 35Kilometers.
    Oct 2011
    #3948
    Quote Originally Posted by amir1223 View Post
    Thanks bro! lubricate ko muna hinges and see if it will work. If not then, sa hydraulic lifter na nga ang problema although hindi pa naman ganon ka critical. Pag hirap na talaga bumukas, then I will have it replaced na. 1 set yan pag binili?
    Jun 2012
    #3949
    Pards, kailangan ko na rin yata palitan yung akin..pa share namn kung saan mabibili yan and how much? OEM ba yan?
    Mar 2011
    #3950
    hindi an nilalagan ng langis or an lubrication...once ndi na mganda kung magfunction an,sira na yan same as mga equipment na ganan ang parts ecept for heav equipment na pede mo taaga iparecondition ang cylinder...pwede rin 1pc pero cheaper if pair bibilhin.
    http://**************/5237403
    Mar 2011
    #3951
    Quote Originally Posted by nicnoc View Post
    san mabibili?---sa kin bos...
    Jul 2012
    #3952
    sir amir1223, meron ka rin bang plastic/rubber floor mat & cargo tray ng innova '12?
    Oct 2011
    #3953
    TIA
    Depends on your need. If you will be carrying many passengers all the time then go for D4-D. If not, then VVTi should suffice. AFAIK, the choking problem of D4-D has already been resolved.
    Oct 2011
    #3954
    thanks sir amir, will pm you if the problem of the rear door becomes worst. bearable pa naman sa ngayon.
    Jan 2011
    #3955
    Tulong lang po, kinagat ng daga ang wiring harness ng innova ko and umilaw yung ABS indicator, covered po ba ito ng comprehensive insurance, may AON (acts of nature) yung insurance ko, dami naputol na wire e, sabi sa casa maganda daw palitan na harness kasi bagong bago pa innova ko, nung may 30, 2012 ko lng po sya nakuha, tnx po
    Oct 2011
    #3956
    Quote Originally Posted by zero4 View Post
    Yes, I think it is covered. Call your insurance para magawa na yan.
    Jan 2011
    #3957
    tnx boss Retz for the quick reply
    Post ko lng po itong link na ito, to download the file, its very informative para sa atin toyota lovers,
    (************.se/*******/6529591/Hilux_Service_Manual)
    ayaw pumasok ng website, sa ******* na website nyo na lng po search
    Jun 2012
    #3958
    Sir Amir..pa pm namn how much thanks.
    Dec 2007
    #3959
    Saang portion ba? Tatlong portion kasi yan, the main wiring harness from the cabin, left sensor and right sensor. Mine was damaged by the dog sa main harness three times!!! DIY ko lang ang repair (alaktrician ini.) pero I already have a brand new harness that I bought from casa na nakaready just in case I really need to replace. Php 4K+ ang price. Kung ito lang damage baka di mo maclaim because of your participation.
    Sep 2011
    #3960
    Mga Sir parehas po ba Size 6 yung Front And Rear Speaker ng innova ?
    o size 4 sa unahan sa rear lang ang size 6.
Toyota Innova Owners & Discussions [continued 3]
