Results 15,381 to 15,390 of 15485
- Jul 2024
- 15
July 5th, 2024 07:57 AM #15381Good day Tsikoteers. I have Innova 2013 G D A/T with 85K odo. May recurring unusual noise galing sa dash board tapat ng passenger side. Parang tunog ng fan na may tinatamaan na lata. It usually starts when the gear is engaged and stops when the speed gets pass 40kph. Pag high speed sa highway, nawawala, pero pag bababa yung speed to less than 40kph tutunog nanaman. Pagnaka neutral or Park nawawala din.
May nakakaalam ba or nakaexperience kung ano cause nito? TIA.
- 54,282
July 5th, 2024 08:21 AM #15382
- Jul 2024
- 15
July 5th, 2024 08:43 AM #15383
- 54,282
July 5th, 2024 09:08 AM #15384
July 5th, 2024 09:26 AM #15385
Does it coincide with how much vibration the engine is making? On both the 2KD and 1GD (w/o a balance shaft), the engine vibration is most pronounced around the 1K RPM (±200 RPM) region. It smoothens out below or above that range.
If I were to guess, it's most likely the engine support(s) giving out.
- Jul 2024
- 15
- Jul 2024
- 15
July 5th, 2024 09:46 AM #15387
July 5th, 2024 10:12 AM #15388
- Jul 2024
- 15
July 5th, 2024 11:38 AM #15389Here's a video. https://streamable.com/wcjft5
The sounds appear Pag low speed/rpm . Nawawala Pag naka neutral/reverse, nawawala sya Pag mabilis takbo .
July 5th, 2024 12:59 PM #15390
Try mo ito:
1. Have someone sit in the driver's seat
2. Go to the passenger side and look under the dashboard
3. Have the driver rev the engine until the sound appears
4. Localize mo kung saan nanggagaling yung rattle
5. Reach out and try to touch the different parts in there and see kung magbabago tunog or if it dampens the rattle
Sa area na yan, andyan yung A/C and computer boxes. I suspect there's a screw loose in there somewhere or may nagbabanggaan na metal parts.
Naalala ko iyong 2013 SJ Forester ng relative namin. FMC change siya ng time na nakuha sa casa. ...
Yaris Cross 1.5 S HEV CVT vs BYD Sealion 6 DM-i
