Page 1540 of 1549 FirstFirst ... 144014901530153615371538153915401541154215431544 ... LastLast
Results 15,391 to 15,400 of 15485
    Jul 2024
    #15391
    Try mo ito:
    1. Have someone sit in the driver's seat
    2. Go to the passenger side and look under the dashboard
    3. Have the driver rev the engine until the sound appears
    4. Localize mo kung saan nanggagaling yung rattle
    5. Reach out and try to touch the different parts in there and see kung magbabago tunog or if it dampens the rattle
    Sa area na yan, andyan yung A/C and computer boxes. I suspect there's a screw loose in there somewhere or may nagbabanggaan na metal parts.
    What I did was I removed the glove box and yung isa Pang cover sa taas nya. Then we drive and checked if dun galing yung rattling. So far, wala don yung rattling noise.
    Jul 2024
    #15392
    Quote Originally Posted by Xchocoh View Post
    I also notice that if pull my windows down I barely hear the rattling sound. As if there's no rattling
    Jan 2009
    #15393
    First thing to do is localize where it's coming from. That's the only time you can do something about it.
    #15394
    Here's a video. https://streamable.com/wcjft5
    The sounds appear Pag low speed/rpm . Nawawala Pag naka neutral/reverse, nawawala sya Pag mabilis takbo .
    ... most strange...
    i kept listening to it, and nothing comes to mind...
    it sounds vaguely familiar, but i can't put my finger to it... para bang something i take for granted... transmission... support?
    hindi kaya... nag-upshift lang ang trans?
    might i inquire,
    how long have you had the vehicle?
    when did the noise start?
    engine support evaluation isn't incredibly difficult. bring the car to a talyer.
    taga saan po kayo? maybe our listeners can recommend a shop near you.
    i once had a strange sound in my 1gen innova.
    it was the air cleaner!
    i had earlier forgotten to re-install the cover's retaining clips.
    check also the air cleaner housing's mounting bolts.
    Jan 2009
    #15395
    If this only started fairly recently and out of nowhere (nothing was changed, repaired, or modified in the car), check all cubby holes inside the vehicle.... center console, cup holders, door pockets, door armrest, etc. Sometimes, passengers will inadvertently stow away loose items in there like coins, hair clips, or children's toys that can rattle.
    Jul 2024
    #15396
    ... most strange...
    might i inquire,
    Ilocos Laoag location ko po . New discovery, Pag naka idle sya at may tao sa front meron yang rattling sounds, Pero Pag walang tao sa driver side/passenger nawawala sya. ��
    Jul 2024
    #15397
    ... most strange...
    might i inquire,
    About a month . Bought it sa second hand dealers samin . Then nag change engine oil, ATF ako then byinahe sa pagudpud ng pinsan ko (from Laoag). Pag balik ganyan na. Wala naman yan dati .
    Tsaka nawawala yung rattling sounds Pag walang tao sa driver side at passenger side.
    #15398
    yikes!
    ... katawan nang sasakyan issue...? have the vehicle lifted at the gas station and take a hard look undersides.
    loose screw...?
    Jul 2024
    #15399
    yikes!
    loose screw...?
    Will do. Pa check ko Rin bukas supports baka dun din galing.
    Jul 2024
    #15400
    Quote Originally Posted by sirkosero View Post
    ... and it can only be heard from the inside while rpm is less than 2k?
    Its the passenger airbag. Remove it or atleast lift it put foam or double sided tape underneath. That should minimize if not eliminate the noise.
    Nakakairita tunog nyan.
    This is the solution of my problem . I removed my passenger airbag and the rattling noise disappear. My only question is, which part exactly should I put some foam or tape? Tia.
Toyota Innova Owners & Discussions [continued 3]
