Page 1243 of 1549 FirstFirst ... 114311931233123912401241124212431244124512461247125312931343 ... LastLast
Results 12,421 to 12,430 of 15485
    #12421
    Imperfect is one thing. Downright ineffective (re: re-circulation mode) is what Toyota did to these cars.
    Anyway, you're not going to die of CO if there's no outside exhaust gases coming in. Pwede pa CO2 intoxication. But that will mean you'll have to be in there for a long time.
    that bulkhead in front of the front passenger and driver, has holes connecting the engine bay to the passenger cabin, where the control cables, tubes, and steering column pass thru. it's supposed to be sealed, but, you know... wear and tear and all that.
    how effective or in-effective are these seals? in the past, there were several deaths believed to be from carbon monoxide poisoning, in parked, idling cars.
    #12422
    Quote Originally Posted by antonath View Post
    Good year auto care olongapo qoutation for 20k pms. Talo pa ang doctor kung magsulat. Almost 7k.
    parang handwriting ng duktor.. hirap intindihin.
    but you go home with a resibo, 'di ba? ang duktor...?
    heh heh heh.
    Jan 2009
    #12423
    I'm referring to the flap/vent design for routing in outside air. The problem with this vehicle platform is that the flap leaks a lot more outside air than most other vehicles. So just to put a number on it, let's say a typical car would only leak 5% outside air and 95% is recirculated cabin air. On the Innova, it's more like 20-30% outside air and the rest is recirculated air. Coming from driving a sedan for 7 years and driving the Innova, the result is very noticeable.
    To illustrate (this took me a while to draw so bear with me), here are rough cross-sectional drawings of a part of the Innova's A/C. When the mode switch is set to Outside Air, a flap (blue part in the drawing) moves up to open up the outside air vent and at the same time, blocks the cabin air from recirculating. In this mode, the A/C is pulling in practically 100% outside air.
    When you set it to Recirculate, the flap moves forward to block outside air and allow cabin air to flow. As you can see in the design, the tolerance between the flap and the outside air vent is too big and as a result, a significant amount of outside air is still getting in.... much, much higher than typical.
    #12424
    That is deliberate and strategic bro.
    "Confuse the enemy!" (and the battle is half-won)
    _/_/_/
    30.9K _/_/_/_/_/_/_/_/_/_/
    Aug 2009
    #12425
    So this is the reason why the aircon filter is very dirty even after just 1 change oil which i don't expect when using recirculate mode.
    Kahit pala 10 years na kami may Innova, I/We do really learn something new everyday.. Thanks for sharing!
    Jan 2009
    #12426
    Quote Originally Posted by Sleepcare View Post
    Exactly.
    My old Civic could go a year and the cabin filter will only exhibit a grayish discoloration. But on my Innova, just using it for 4-6 months and a portion of the filter would already be black with soot.
    It's that bad.
    Jan 2009
    #12427
    planning to replace 2 tires ni innova sa likod, bago pa kasi yung front. is it ok kung gamitin ko sa likod is 205/70/r15? while sa harap is stock 205/65/r15, may masama ba effect yun? then pag luma na yung harap gawin ko na din 205/70
    #12428
    nice diagrams. i couldn't do those even if i wanted to.
    Oct 2015
    #12429
    Hi guys need your help. Can anyone recommend a fairly affordable parts shop that sells Innova side mirrors as well as an affordable repair shop to install said side mirror? Got into a nasty incident wherein my Innova's side mirror (including the part that connects it to the pillar) was completely sideswiped, meaning wala na siya completely. Wasn't able to retrieve the side mirror since I was in a highway, and I guess unusable na rin yun if ever.
    #12430
    Quote Originally Posted by rpv5 View Post
    try the online sellers, po.
    just now, there's someone in olx, advertising his innova side mirror.
    then there's the cathay centers in banawe and evangelista, where glib-of-mouth is the weapon of choice.
    good luck, po.
Toyota Innova Owners & Discussions [continued 3]
