Page 1483 of 1533 FirstFirst ... 1383143314731479148014811482148314841485148614871493 ... LastLast
Results 14,821 to 14,830 of 15330
    Nov 2011
    #14821
    Quote Originally Posted by sirkosero View Post
    Agree. Toyota will just say "fix what?" Unless you can prove factory defect siya that no one else feels but you
    Sent from my MI MAX 2 using Tsikot Forums mobile app
    its not me who needs to prove it, its their seat foam supplier who should have foam firmness tester that they should have on manufacturing the foam seats. if they dont have such, then they just manufacture without standards and should replace on/by demand/complaint...
    dati nung si uratex pa ang supplier ng foam eh meron sila tester, even sa display showroom ng beds nila ngayon eh meron sila tester, di ko lang alam sino supplier ng foam seats ngayon, ayaw ko naman baklasin yung seats para lang malaman sino ang supplier/manufacturer...
    Nov 2017
    #14822
    Quote Originally Posted by jresperanza View Post
    thanks for the info, i think di pa ito need ko kase yung same variant na display unit sa casa eh mas comfortable talaga versus mine, infairness masakit pa puwet ko pag punta kasa pero the moment na umupo ako dun sa display unit eh ang sarap...
    Mas matigas ba or mas malambot ung upuan sa problem area comapred sa demo unit or may parang nakausli? If the later baka mas madaling i push for replacement pero kung ung former baka sabihin lang na mas gamit ung upuan ng demo unit at kelangan lang gamitin ung sa unit mo.
    Nov 2011
    #14823
    i'm thinking of going to seatmate.
    if they can re-configure my wigo's driver seat, to make it more comfortable for me...
    OT.
    yes, checked that, seatmate is charging me a min of 9500 for all leather seats, too steep for a bnew car na mas comfy pa yung same variant na naka display sa casa
    Quote Originally Posted by sepskee View Post
    buti napalabas mo yung doctor .. pinaupo ka pa sa oto nya .. friend mo ba? heheh
    good luck sir, hope maayos mo na issue mo dito
    yes, neighborhood friendly spiderman siya
    Nov 2011
    #14824
    Quote Originally Posted by TsekwangBakla View Post
    Bili ka ng upuan ng Mirage sa Banawe, tapos ilipat mo sa Innova. Solve na yung sakit ng puwet mo pag sumakay ka sa Innova.
    cant do, bNEW july 2021 vehicle ito, under warranty plus company owned vehicle ito...
    Nov 2011
    #14825
    Quote Originally Posted by LOLZ View Post
    yung sa unit namin ito nasa pula ang matigas kaya iniiwas ko pwet ko dito at dun ako sa green umuupo (likod ko naman ang sasakit kase di naka sandal ng ayos) o kaya naman nilalagyan ko ng twalya para kahit papano di ko siya maramdaman, may improvement kung may twalya pero nakaka inis kase nag iislide yung twalya kada galaw ko / upo ko tska brandnew ito july 2021 baket ko kailangan gawan agad ng paraan
    yung upuna sa casa na naka display unit (same variant) eh manufactured Sept 8, 2021, mas malambot siya dun sa pula part, yung unit namin manufactured June 26, 2021. nung una kuha pa lang namin sa casa eh may naramdaman na ako, pero di pa agad ako nag reklamo kase akala ko naninibago o may mali lang ako sa adjustment ng silya, pero habang tumatagal eh mas lalo lumalala yung sakit...
    #14826
    Quote Originally Posted by Terrence View Post
    Good day! notice ko sa innova ko 1st gen diesel after I start parang matagal before it reaches the normal temperature I think it takes about 30 minutes. Ask ko lang if same din ba sa inyo?
    Looks like you need to check on your thermostat as dr. d mentioned. Might be stuck open. Easier to check on cooling systems with the pressure cap on the radiator itself. If that's the case for 1st gen innovas then you can check it yourself by opening the cap in the morning after starting the car. Coolant should not be flowing by when you look inside the radiator's cap hole.
    2nd gens have the cap on the overflow so the same procedure above is not possible. At least from what I can see on mine. Or maybe there's a way that I don't know of.
    #14827
    Quote Originally Posted by blank check View Post
    nakuser,
    all my 1gen diesel innovas' coolant filler caps, are on the overflow cannisters...
    #14828
    nakuser,
    Wondering which configuration is better between using a pressure cap on the radiator (my gen 1 vios, and all previous 90's car we had) and those having their pressure caps on the expansion tanks (I guess it's safe to say for all Innovas, Hi-Lux and Fortuners).
    Anyway, my innova gets to its operating temp (~90ish Celsius) in about 10 minutes I think. Will check tomorrow when I drive the in-laws to the airport
    Jan 2009
    #14829
    On my Diesel 1st gen Innova, it takes forever to reach operating temp (temp needle midway through the gauge) when it's just idling. The warm-up is faster when you just drive it a few kilometers.
    Still, my Civic warms up quicker, even when idling. In fact, when I switched to the Innova, I, too thought that the thermostat was faulty. That's until I tried my brother's Innova. So I'd say it's normal for this vehicle to take longer to fully warm-up.
    If I were to wager a guess, it might be because of the hefty hunk of metal that is the engine block that Diesels have. It has a larger thermal mass compared to a gasoline engine so it can soak up more heat.
    Apr 2010
    #14830
    kasya yung Baldwin B2 versus the BT223 na direct replacement for the Toyota oil filter. this is for the 2KD, not yet sure sa 1GD engine.
    sinubukan ko ilagay sa Innova kasi marami akong inorder na B2 for the NP300, pero may minor leak kahit same thread naman
    micron rating is better: B2 | BT223 and at 1.5x the length, mas maganda ang filtration.
Toyota Innova Owners & Discussions [continued 3]
