Page 1423 of 1549 FirstFirst ... 132313731413141914201421142214231424142514261427143314731523 ... LastLast
Results 14,221 to 14,230 of 15485
    Jan 2009
    #14221
    Quote Originally Posted by jovz View Post
    tanung ko lang po kung ano po possible cause ng tulo sa may passenger side po gawa nababasa po un flooring
    Most likely, condensate from the A/C. Check the drain hose if it's loose, blocked, or broken.
    May 2010
    #14222
    Share ko lang. Kahapon nag palit ako ng clutch set at kahit ng aux fan (sa harap ng consender)
    * Clutch Set - P5,500
    ** Clutch Cover - Aisin
    ** Clutch Disk - Aisin
    ** Pilot Bearing - Koyo (same as orig)
    ** Release Bearing - Koyo (same as orig)
    * Labor - P2,500
    * Aux Fan - P680
    ** Fan - Sanden 80w 12 volts. 12 inches size (10 inches blade)
    ** Relay
    ** Fuse
    * Labor - P950 (napamahal. kay mang Danny 400 lang sabi niya dati)
    Dec 2019
    #14223
    Parang common issue ba to sa new innova sir?
    Dec 2019
    #14224
    Tama. Was an issue in my 80 series before. Same thing parang na misalign ata
    #14225
    Hello guys!
    do any of you know approx. how much a throttle pedal position sensor costs now? 2006 Innova D4d manual. saka saan kaya aa south mura makabili or sa banawe?
    thanks
    Jun 2005
    #14226
    Quote Originally Posted by Louga View Post
    * Labor - P2,500
    * Aux Fan - P680
    ** Relay
    ** Fuse
    Ano model inno mo? Saang shop ka nagpagawa ng clutch? Bukas kahit sunday?
    San ka din bumilinng parts?
    Sent from my MI MAX 2 using Tapatalk
    #14227
    * Labor - P2,500
    * Aux Fan - P680
    ** Relay
    ** Fuse
    aux fan?
    whypo?
    my innova does not have one.
    May 2010
    #14228
    aux fan?
    whypo?
    Pang tulong lang po pag summer at babad sa araw. Ok naman a/c ko so far. Murang upgrade lang din kaya ok na din.
    Sumasabay lang sya sa compressor. Pag pitik ng compressor pitik din yun fan.
    May 2010
    #14229
    Quote Originally Posted by sirkosero View Post
    2009 gas m/t 140k kms.
    Auto shop: Will power auto supply. Along East service road (katabi pizza hut) in between FTI and Bicutan. Dealer sya ng Aisin. Mas mura kesa sa Pasay.
    May katabi na autoshop din ito Vegar pangalan mura din don.
    Note; ang orig na release bearing ng innova ko ay koyo brand. yun binigay sakin ay NSK na mahal mali pla so be aware lang. See attachment non pinapalit na bearing na same sa orig pati yun number.
    Yun orig ko na clutch cover at plate parehas Aisin uu tatak non binaklas.
    Shop: Petron gas station. West service road in between sun valley and merville. Pag galing ka south 1km away from Toyota bicutan. Look for Teody. 09303260561. Sarado sunday unless pa appointment ka. Tawag muna bago magpagawa kc dami nag papaayos sa kanya mag 1 lng sya. Doon din ako nagpagawa pang ilalim ko 3weeks ago. Maayos gawa hindi madaya.
    List of Aisin Dealers
    Parañaque - Grand Sucat Auto Supply/Cruiser Parts Center/Willpower Auto Supply
    Banawe - Toyorama/Toyocars
    Masangkay - Riken Motor Sales
    Will power info. Bukas linggo 1/2 day. Willpower Auto Supply - Auto Parts in Paranaque
    Attached Thumbnails Attached Thumbnails 20200301_112537.jpg   20200301_115608.jpg   20200301_103533.jpg   20200301_103553.jpg
    Feb 2006
    #14230
    thanks po sir check ko din nga po pala ito
Toyota Innova Owners & Discussions [continued 3]
