Dumadami ang Innova Owners dito na girls ha...
:congrats: sa mga new rides nyo![]()
what do you use to clean your dashboard? do you use any protectant like armor-all?
Sir,
Thanks sa advice, tutuo po yan sir, iba ang engine braking ng gasoline engine sa diesel kaya nanibago ako sa pag drive nitong diesel engine.
May share lang po, description from wikipedia about engine braking:
The term engine braking usually refers to the braking effect caused by throttle position induced vacuum in petrol (gasoline) engines. While some of the braking force is due to friction in the drive train, this is negligible compared to the effect from vacuum.
When the throttle is lifted less air is allowed to pass through the intake manifold, and the engine works against this vacuum. It is the deceleration of the engine against this vacuum which provides the braking effect.
Diesel engines vary fuel flow to control power rather than throttling air intake and maintaining a constant fuel ratio as petrol engines do. As they do not maintain a throttle vacuum, they are not subject to the same engine braking effects as petrol engines are.
Engine braking passively reduces wear on brakes and helps a driver maintain control of the vehicle. Active use of engine braking (shifting into a lower gear) is advantageous when it is necessary to control speed while driving down very steep and long slopes.
It should be applied before regular disk or drum brakes have been used, leaving the brakes available to make emergency stops. The desired speed is maintained by using engine braking to counteract the gravitational acceleration.
Improper engine braking technique can cause the wheels to skid (also called shift-locking), especially on slippery surfaces such as ice or snow, as a result of too much deceleration. As in a skid caused by over-braking, the vehicle will not regain traction until the wheels are allowed to turn more quickly; the driver must reduce engine braking (shifting back up) to regain traction.
Engine braking is intrinsically available in non-hybrid vehicles with gasoline-powered internal combustion engines, regardless of transmission type. In almost all cases, it is active when the foot is lifted off the accelerator, the transmission is not in neutral, the clutch is engaged and a freewheel is not engaged.
In hybrid electric vehicles like the Toyota Prius, engine braking is simulated by the computer software to match the feel of a traditional automatic transmission. For long downhill runs, the "B" mode acts like a lower gear, using higher RPMs in the internal combustion engine to waste energy, preventing the battery from becoming overcharged.
Medyo broad pala ang definition ng Engine Braking, to summarize, i need to adjust my driving habit
I hope wikipedia's explanation above may find helpful to others...in one way or the other
Regards,
Mae
[quote=celina mae;1701086]SiR,
Thanks po, orange ang kulay,magandang itakbo sa highway at kahit medyo mabilis ay stable ang takbo,since na malapad nga ang tires, yun nga lang kapag nasa 120-140 ka ay may humming sound na sa tires.
Pinacheck ko sa Honda Caloocan, then sabi nila ay mabigat daw ang wheels at tires kaya induce ng humming sound kapag mabilis.Anyway maximum speed discipline ko ay 120 lang po, inahabol ko lang minsan ang wala ding disiplina na mag cut sa toll ways..he he he.
Black po ang innova ko, dsl G variant m/t, i choose m/t since sanay na po sa clutch at shift gear, medyo may fun kung may galaw ang kamay at paa sa driving di ba? medyo kakaantok po yata ang a/t,sorry po sa a/t owners, opinion ko lang po ito.In terms of convenience lalo na sa traffic ay maganda po ang a/t.
May ask lang po ako sa ating mga professional drivers at mechanic, I use to apply engine braking before stepping on the brake pedal naging habit na po sa driving ko, thats why i preferred m/t.
Ano po ba ang disadvantage ng Engine braking? ang alam ko lang po ay very smooth and fast ang deceleration and it's always a fun for me hearing the engine respond sound...complain po ang kids ko the way I drive, mali daw po ang Engine braking???
Regards po and happy driving with care.
Enjoy po ako dito sa site, very helpful po ang mga members.
Mae[/quot
Ang ibig nyo po bang sabihin eh nagda down shift kayo.. say gear 5-4-3-2-1 until malapit na huminto tapos neutral then preno?? very active feet at kamay nyo kung ganun... well ginagawa ko po yan sa nlex bago mag exit sa tabang pag naboboring ako.. ok lang po yan basta sakto lang yun decceleration ng sasakyan nyo bago mag down shift para di sumubsob mga sakay nyo at di rin mapahirapan engine nyo...
actually sa 4th and 5th gear po di nyo marandaman engine braking. most of the time ginagamit po ang engine braking kung pababa yung kalsada lalo na at mahaba yung stretch ng kalsada na pababa like marcos hi way from baguio pag di ka gumamit engine brake dun at aasa k sa pitik ng pitik ng preno nakakalamang mamakat preno mo.
Good day po. I just got my 2nd hand innova ( 2006 G A/T Gasoline) last week, so far i'm satisfied sa perfomance compare to my old Mitsu Adventure. Just have some few questions and I hope somebody could enlighten me
1. My gas consumption is playing from 6.5 to 7kms /L (City Driving) and 8-9kms/L ( Long Drive). Is this really normal on my variant/model?
2. I can hear the Engine Fan from inside during rev, again is this normal?
3. I had a semi-flat tire the other day, what i did was to put a jack first overnyt to sustain the psi of my tire. Now, i notice na nde na pantay ung tindig na oto ( Nainis tuloy ako sa sarili ko bakit jina-ckan ko pa hehehe) , Pano ko kaya mababalik sa dati ung height?
4. Last na po, everytime kakabig ako, laging may lumalagutok sa ilalim ( Driver Side), nung pinacheck ko sa mekaniko ko sabi sa body na daw ung problem, hayyyy... may naka experience na ba sa inyo nun?
I'll appreciate your comments guys.
Thanks!
[quote=g2pharma;1701189]
Sir,
Tama po,hindi maramdaman sa 5th to 4th gear, pero sa 4th to 3rd or 3rd to 2nd ay very effective po lalo na't medyo kabisado mo na ang behavior ng car mo ,synchronize mo na ang clutch at gas pedal.
Dito po sa new rides ko na innova dsl m/t, hindi ko po magawa yun, medyo hindi ganun kabilis ang braking deceleration response compared sa sedan gasoline engine.
Medyo familiar po ako sa Electrical braking ng Electric motor, wherein you can utilize the energy stored on it to regenerate power and acts as a generator to oppose the rotation-electrical braking, followed by mechanical braking which involves disk or a drum brakes.We call it zero speed, before applying mechanical breaking...sa crane at elevator po kasi ang line ko, so medyo familiar po sa types of braking, but not in combustion engine
Tried ko pong apply sa combustion engine, it seems the same principle! u can utilize the engine speed to act as a primary brake then apply the rubbing pad ( disk brake) for a nearly stop..to complete stop.I'm not after to save the brake linings, just want to prove the same power principle of rotary machines, very risk curiosity!
Lets say you're running at 80 kph, then shift your gear to Neutral, the car will continue to run! because you have already the power and momentum stored.By utilising this energy CORRECTLY, you can stop the car using its own power...dont rely on mechanical disk brake specially during emergency.
Well,please don't try or follow my braking technique! it may endanger yourself and the engine as well.
Share lang po,a friend of mine, girl din po siya at buo po ang loob. While running at 120 sa tollway at 5th gear ( in Jakarta,Indonesia)on the way to the airport, nagstop pong bigla ang nasa front niya, 5 vehicles banggaan sa front, she cannot rely anymore with her disk brakes alone to prevent the impact to the front vehicle, in a split of second she was able to shift the gear from 5th to 1st!!! very fast deceleration time..Save po sa accident...although damage ang Mechanical transmission ng car niya...uh
Ingat po sa driving,anything can happen.Don't forget the Engine Brake Power!!!
Mae
sir yung sa gas consumption pareho po tayo ng readings (innova J gas 2009)
yung about the engine fan na naririnig mo yung sa akin so far wala pa naman ako naririnig sa akin,minsan nga nakakalimutan ko na naka on pala yung engine ko nag click ako uli ng start OUCH!!!patay ang starter ko yan
yung about the height problem i read somewhere here sa mga thread may nagkarun na ng ganyan na case pero yung sa kanya BRAND NEW pa lang ganyan na dinala nya sa casa eventually naayus naman but it took him 2 balik ata eh as far as i remember, i think pa check mo na lang sa casa para ma diagnose lang kung what happend,am not sure kung may diagnostic fee ang toyota eh
yun huli naman madami causes ang lagitik i think,if u want try mo dalhin sa banawe WHEELERS magaling sila sa under chasis hindi ka pa peperahan banawe corner N roxas,pa chek mo na din dun yung sa height problem mo dun sure ako wala diagnostic fee
Mae[/quote]
Grabe presence of mind nung friend mo. bihira nakakagawa nun.usually preno sabay kabig...
magsuffer talaga pyesa ng trany pag ganun.
IMO, you can't compare the Civic, being a sedan to the Innova, being an MPV... it's but natural na matagtag ang civic dahil mababa ang ground clearance... ramdam nya talaga ang tagtag ng 17"... ang Innova naman ay medium sized at high ground clearance... tama lang na mas malaki ang gulong nya for better grip on the road... 55 series would be the ideal size of the tires... IMO, anything na mas manipis pa dyan will definitely make the Innova mas matagtag.
just my two cents![]()
sa casa mo na lang dalhin bro... ganun din naman ang charge pag sa labas mo ipagagawa... per panel din ang singil nila... try mo mag inquire sa Tyt Otis... last year kasi nung masagian bumper ko... 3K nila ako siningil sa pintura... syempre may extra cost kung may clip na kailangan palitan o brace na dapat i align... may warranty pa sa casa, kaya pwede mong ibalik kung may makita kang defect sa workmanship.
on the other hand...ok lang din naman sa labas kung kilala mo na ung talyer at kabisado mo na gawa nila.
Hi Sir,
You maybe correct with Innova,mas maganda po siguro ang absorber.
Di rin pwede siguro i compare ang sedan sa avanza na medyo matagtag na talaga ( Multi purpose din po ba ang Avanza?).
Kasi po minsan ay rent kami ng service car, Avanza ang binigay na naka 17 ang mags, grabe po ang sakit sa katawan sa tagtag.Next day po ay pinapalitan na namin kaagad.
Additional input pa siguro sa ibang member lalo na po sa naka 17 mags sa Innova para magka idea ang nag inquire
Mae
Mam Mae,
matagtag po ang ride pag manipis po series ng tire, like series 45 dapat po series 55 para di po matagtag.
--jazkingpc
ok tol..
anu ung pinahigpitan mo sa baba? maliban sa pedal
Hello marz,
Thanks for the info,I'm using 17 inch Falken Ziex ZE-512 for my honda civic, low profile kaya po siguro mas limited ang flexibility sa medyo rough road, di gaya ng stock tire.
With my new Innova, smooth po talaga ang ride with original wheels of course.
Di kaya ma void ang warranty ng new unit kung mag upgrade ang ibang owners sa 17 mags and tires, inquire siguro sa casa
Regards,
Mae
