Results 791 to 800 of 2001
August 12th, 2013 06:44 PM #791
^Pangtapat sa Hyundai GS Limo. Mga bubong -sayad garahe specials. :D
August 13th, 2013 09:40 PM #792
August 13th, 2013 11:51 PM #793
- Dec 2006
- 43
August 14th, 2013 01:45 AM #794
August 14th, 2013 09:20 AM #795
- Feb 2013
- 157
August 22nd, 2013 12:58 PM #796hello all,
i'm currently using an office issued 2000 hi-ace grandia and noticed that FC is quite high already the past few months. the only obvious symptom that i see (or feel) is the loud shudder upon turning the engine off. starting it though is a snap.
mileage is already 220K and in the 3 years that i've been using it, maintenance is just the annual oil and filters change.
hope you can help me pinpoint the things i need to look into should i have this serviced.
thanks!
August 22nd, 2013 01:13 PM #797
Try to use 2T every time you load up with diesel
August 22nd, 2013 01:54 PM #798
Given the mileage, you have to check the belts if due for replacement na...kung may loud shudder, pwede ring mga engine or transmission support...
- Feb 2013
- 157
August 22nd, 2013 02:19 PM #799mr cb,
thanks...yeah saw the thread about this and looking to apply it as well
mr mateo,
well noted your points. will look into this. thanks!
August 22nd, 2013 02:33 PM #800
also check if kailangan na ba mag tappets adjustment. im not sure if self adjusting tappets ba or hindi yung engine niyo e
A 70/30 water to coolant mix may improve cooling efficiency but that's at the cost of less...
Coolant...
