Page 1 of 5 12345 LastLast
Results 1 to 10 of 49
    Jul 2010
    corolla 2e engine, running 80kph (5thgear) at 2700rpm. ganyan din po ang sa inyo na 2e engine?
    Aug 2010
    Quote Originally Posted by devond View Post
    di ko sure e, wala kasi tachometer yung akin e.
    syempre it varies depende kung kailan nagshishift
    primera ano rpm nag shift? segunda ano rpm? and so on
    kung fifth gear ka na tapos 80 lang takbo mo parang maaga ka nagshishift
    Aug 2012
    huh?! Ganun ba yun?
    syempre
    kung nagrev ka till redline sa bawat gear syempre pag dating mo ng fifth gear mas mabilis speed mo compared to shifting early in each gear
    Jan 2009
    I think that the OP is asking for input from other owners using the same engine with regards to what RPM reading their car is showing while cruising at 80kph in 5th gear.
    It has nothing to do with shift points.
    What would have an effect on the results would be if the clutch is slipping or if the tachometer and/or speedometer are not accurate.
    2700rpm for 80kph *5th gear?
    wala akong rolla 2e, pero parang mataas yata yung 2700rpm even on other cars?
    sounds like he's trying to accelerate at 5th gear
    baket nasa 5th gear na pero 80 lang ang takbo?
    baka sa 1st gear hanggang 20-30 kph lang, 2nd gear 30-40, 3rd gear 40-50....
    fuel efficient mag drive
    it's a manual trans, right? has nothing to do with shift points.
    my diesel MT innova does 80 kph at a little over 2000 rpm.. 2100 or 2150 rpm, i think..
    is it possible, your speedometer is not as accurate as before?
    not 2e but this is my point
    start at 40 secs
    [ame]www.youtube.com/watch?v=XOP_3gVSlCE[/ame]
rpm/kph
