Results 5,511 to 5,520 of 5535
August 23rd, 2024 04:06 PM #5511
Inisip ko nga kung 4 kasi I am not sure if I will sell my car next year.
Casa said rear nga lang may damage pero most people naman palit lahat talaga?
If I sell my car sobrang swerte bibili, 45k lang tinakbo. All 4 ignition coils brand new replaced sa casa, kung sakali all 4 shocks orig brand new din, plus I am planning to buy new Michelin PS4 tires pa (all 4 rin).
Kinakabahan kasi ako sa CVT issue, since my car turned 10 already
I called Toyorama. Here is the quote for Original
Front Left P6330
Front Right P6550
Rear Left and Right P4130
Labor (in house/tambay haha) P1500 for all 4 shocks
Ayoko ng KYB, as much as possible I always replace all parts with original kasi. I read stiff din daw KYB?
Isn't Speedyfix in San Juan? Our driver brought my Gen 10 na there for oil change
- Jan 2007
- 2,587
August 23rd, 2024 04:37 PM #5512Far as I know Toyota doesn't make their own shocks.
If you check the engravings on those OEM Toyota shocks you'll probably find engravings for either KYB or Tokico (in addition to Toyota).
More likely KYB ata for their small cars, Tokico is for bigger vehicles like the Land Cruisers.
Informational lang, not discouraging you from buying original. It's very possible, even likely na iba yung manufacturing spec for a KYB-built shock meant to be sold as OEM Toyota vs one they'll under their own brand.
August 23rd, 2024 04:53 PM #5513
August 23rd, 2024 04:58 PM #5515
- 54,206
August 23rd, 2024 05:07 PM #5516i use kayaba (KYB! heh heh).
after several years, i had already forgotten when i replaced them, and they are/were still fine.
if you have a choice between regular and heavy duty, go heavy duty. they make for smoother ride. or so google says. heh heh.
oem simply means, the brand and model that manufacturers use in their assembly lines. it does not necessarily mean the manufacturer manufactures it, as well.Last edited by dr. d; August 23rd, 2024 at 05:09 PM.
August 23rd, 2024 05:12 PM #5517
Unless you have a particular application (transporting heavy loads, etc.), I would recommend against heavy duty shocks.
August 23rd, 2024 05:14 PM #5518
August 23rd, 2024 05:23 PM #5519
- Jan 2007
- 2,587
August 23rd, 2024 05:34 PM #5520It's possible kasi that the spec is different. Baka the ones they make for Toyota are heavier duty than the ones they sell themselves. Can't really tell for sure without getting both shocks and cutting them up to compare.
Here's a 3-page discussion on KYB vs OEM Toyota from another forum:
KYB vs OEM struts
Personal opinion though knowing which OEM makes the original parts for your car is one of the veteran tricks to saving money on maintenance. Like getting Aisin instead of Mitsubishi/Subaru water pump, etc.Last edited by Dr.Kamiya; August 23rd, 2024 at 05:39 PM.
Hope we see significant changes.
