Results 5,411 to 5,420 of 5535
- Jan 2008
- 4,726
May 19th, 2021 10:37 AM #5411actually sir, kahit dun sa altis namin na 2002 model, may naka sulat na "lifetime ATF" to that effect.. na no need to replace under normal conditions..
kaya siguro sinabi naila na "non serviceable" kasi walang dip stick yan mga bagong transmission.. pero may tamang teknik naman sa pag replace ng fluid nyan.. may toyota specific tools na din yata to refill the transmission.
80k or 100k kms is the best to replace the fluid lalo na kung normal city driving lang naman with occasional expressway trips.. pero kung heavy use like hauling or parang fleet use na almost 24 hours tumatakbo, baka every 40k kms dapat replace ng fluid
May 19th, 2021 10:59 AM #5412
Yung mga CVT-equipped Subarus have no dipstick. However, there is a way for the CVTF to be replaced via the drain-and-refill method or the more complex dialysis method.
On such Subarus, there is a drain plug on the bottom of the engine to drain the CVTF and a spout on the right side of the engine where the CVTF can be funneled.
For the Mitsubishi ASX, the CVTF was funneled thru its dip stick. I changed the CVT before 40k km.
May 19th, 2021 02:35 PM #5413
the subaru one seems similar to what toyota details in their repair manual for the corolla however has an additional step that requires a scan tool for adjusting the fluid level at operating temp.
Toyota Service Information
May 20th, 2021 06:22 PM #5414
CVT fluid changed today.
Thanks to bro Egan101 for referring 2211 works.
May 20th, 2021 07:49 PM #5415
May 20th, 2021 08:29 PM #5416
And they say Toyotas are easier to work on. Doable naman, pero parang ayaw din talaga ipagalaw ah.
Just recently changed myself the ATF on a Ford, which many would say is a car that’s “hard to work on”. Needed only a wrench, funnel, screwdriver, pliers and jug for measuring the amount that comes out. Done in less than 25 minutes.
May 24th, 2021 11:14 PM #5417
- Jun 2005
- 3,774
May 25th, 2021 11:06 PM #5418Ang tanong... Sigurado kayang pinalitan o siningil ka lang
Sent from my MI MAX 2 using Tsikot Forums mobile app
May 26th, 2021 01:32 PM #5419
well, i have never met a victim admitting they maltreated their trans box...
The Toyota Fortuner has landed (fortuner pics at...
