Page 506 of 554 FirstFirst ... 406456496502503504505506507508509510516 ... LastLast
Results 5,051 to 5,060 of 5535
    Sep 2014
    #5051
    Three and a half years na ang altis ko wala pa namang problema. Ang aircon kahit sa 28 degrees malamig na malamig pa rin.
    Sent from my SM-G920F using Tapatalk
    Jun 2018
    #5052
    Hi,
    Sorry if this is already a repeat question but does anyone know how to turn of the front lights of the car that automatically turns on when you turn the car engine on? It's a white light that I can't really turn off which I'm trying to do. Can't find it on the manual also. Does anyone know how to?
    #5053
    Quote Originally Posted by rushcarr View Post
    Hi,
    Nope you can't turn it off. Those are your daytime running lights.
    #5054
    Quote Originally Posted by Vann-O View Post
    I considered din po ang Civic kaso masyado mababa ground clearance nya dami pa naman hump sa village naming.
    I had both Civic and Altis. Mas konti ang sayad ko sa Civic vs Altis even if the latter has 20mm more ground clearance on paper.
    The Civic has shorter overhangs so wala talagang sabit. Ground clearance is not a reason to forego the Civic vs other sedans.
    #5055
    I noticed in the past week that there is a creaking sound whenever I am on drive and then I step on the brake. At first I would only hear this sound when the radio is turned off, but now I can hear it even with the radio on. Also, I only hear this when I am at low speed or in traffic
    Nakakakaba. Ano na naman kaya problema! So many problems for a relatively new car. Only 28k kms in the odometer
    Jul 2017
    #5056
    *cathy, ilang years na auto mo?
    #5057
    Yan din ang worry ko dati but before I acquired the civic I observed other civics kung sayad, I was surprised na hindi naman pala. As long as gentle ang approach sa humps especially yung pagbaba, no issue sa sayad. FYI, there are 25 humps na madadaanan ko to work one way.
    #5058
    Quote Originally Posted by essjei55 View Post
    4 yrs
    Nov 2011
    #5059
    Hi,
    Look for the DRL fuse and toss it.
    #5060
    Quote Originally Posted by TheUninvited View Post
    check the fuse diagrams, first.
    DRL might not be the only function that will get tossed out.
Toyota Corolla 11th Generation Altis [Merged Threads]
