Results 2,481 to 2,490 of 3568
August 12th, 2015 02:26 PM #2481
see the service records if the shocks and the suspension components have been replaced and have them checked.
also have the tranny fluid, the coolant and the brake fluids replaced.
- May 2011
- 40
August 12th, 2015 03:02 PM #2482
August 12th, 2015 04:54 PM #2483
you may use any oil.... i personally use shell semi-synthetic that i change every 5k kms. same with the tranny oil as long as the specs are the same as the user's manual.
it comes with a chain.
- Feb 2011
- 47
August 12th, 2015 05:19 PM #2484Hi all! Patulong naman saan kau bumibili ng break pad for your altis maliban sa casa. Quezon city area. Thanks to all.
August 12th, 2015 05:25 PM #2485
You may want to replace the serpentine belt just to be sure.
At 80,000kms, palit lahat fluids (transmission, coolant) and filters (fuel, air, cabin).
For fluids, i prefer Toyota Original Long Life Coolant and Gear oil. For your engine oil, chose your own poison.
Toyorama in Banawe for OEM or Bendix replacement. Im using Bendix now but the OEMs are much better overall.
- Feb 2011
- 47
August 12th, 2015 05:50 PM #2486Salamat sir vinj.
Magkano inabot gastos sau kasama labor sa pagpalit?
- May 2011
- 40
August 12th, 2015 05:55 PM #2487
- Jul 2009
- 3,604
August 12th, 2015 06:12 PM #2488
- May 2011
- 40
August 12th, 2015 06:27 PM #2489
- 52,731
August 13th, 2015 12:37 AM #2490- - - - - - - - - - - - - - - - - - - - - -
i suppose that's correct..
when the transmission goes awry, then its lifetime is over.
but sa totoo lang... magkano ba naman ang change trans oil ng MT? give your manual transmission a treat... change its oil at least twice during the life of the car..
high idle RPM at engine start
