Results 1 to 10 of 3575
Threaded View
- Oct 2006
- 261
April 22nd, 2012 07:13 AM #10Ako naman always automatic ang AC, and almost always at 28 degrees except sa tanghaling tapat or nabilad sa araw. Kapag ganon set muna at 25 magma maximum yung blower for a few minutes then minimum kapag na about na yung temp. Di ko pa na try yung set at 21, subukan ko din baka mas effective yon. No unpleasant odor yet, although there is a different smell when you turn off the AC and leave the blower on. Ginagawa ko to minsan pag malapit na sa destination, off the AC and maximum blower, presumably to dry out the moisture inside.
Also did the 15k check up a month ago, currently at 16k mileage, one year last Apr. 16. Expected to increase mileage to 22-30k a year because of the longer distance to work.
Some issues pending so far:
1. The pillar trim rattle is still there
2. Squeaking on the steering wheel column
3. Trunk lid opener in the driver's side not working intermittently
4. There is now a soft kalampag in the rear suspension area in uneven road surfaces
These are all to be scheduled for check up and repair (will claim under warranty), hard to find timing as the car is a daily driver.
FC is at 12-13+ km/li, using full tank measurement, though the computer FC does not vary by more than 1km/li. Estimated 70/30 highway/city driving.
Aside from these, performance is still great and very happy with the car.
No, but it was what sounded closest to Bill, bill. Ha ha ha!
EDSA Rehab/Rebuild and Guadalupe Bridge Repair
