Page 632 of 749 FirstFirst ... 532582622628629630631632633634635636642682732 ... LastLast
Results 12,621 to 12,640 of 14970
    Apr 2008
    #12621
    Quote Originally Posted by arnoldsm View Post
    Nagpalinis na ako ng evaporator ng avanza 1.3j ko. Very extensive ang labor. tanggal buong dashboard, pati steering wheel. I found out na wala pala cabin air filter. Is there a way na pwede mafabricate lalagyan ng air filter?
    same rin pala sa altis you need to remove dashboard, mahal ang labor
    Apr 2009
    #12622
    Quote Originally Posted by woohoo View Post
    Nasa Page 19, ma'am, under MENU SYSTEM. Dun ang start, pero nasa page 23 pa ang pertinent info for you. Please note that I don't have the printed manual, I'm using the .PDF version I got from the web. So, in case iba ang page numbers sa actual printed version, keep reading.
    AFAICR, press the SRC button until you get into STANDBY source/mode. Then press MENU for at least 1 second. Press the Control Knob (Tuner selector) DOWN 2 times. Then press it to the RIGHT once to toggle the AUX setting from OFF to ON. Press Q (MENU) to get out of config mode.
    HTH.
    thanks sir woohoo, i think we have a different manual but i will check it again, in case talagang wala dun sa manual, i follow ko yung instruction mo.
    :thanx:
    Dec 2007
    #12623
    Quote Originally Posted by Lady_fox View Post
    :thanx:
    You're welcome. FWIW, mahirap talagang intindihin yung manual ng Kenwood HU natin. You'll have to be patient and read it from START to FINISH. Ladder-type instructions kasi. Parang uumpisahan ka muna sa 1+1=2, then advanced Addition, then Subtraction, then Multiplication, ganun. You won't understand Multiplication kung di ka pa natuto ng Addition, di ba?
    Kunwari lang yung "AFAICR" ko, I actually went to my Avanza and tried it out before posting that message.
    Apr 2009
    #12624
    make it sure na tama ang turo naku kundi heheheh joke lang po yun.
    i will try it this lunch time. actually print ko na nga instruction mo para di ako magkamali. pupuntahan ko si vanzie sa parking di na ako mag lalunch maayos ko lang ito.
    thanks talaga... pag successful, inform kita!
    Apr 2009
    #12625
    sir woohoo, checked ko manual kanina iba talaga wala dun yung instruction mo.
    anyway, perfect ang instructions mo:cool01:, I followed and I got my AUX up and running! Thanks talaga...
    #12626
    Quote Originally Posted by jaspi11 View Post
    sa kasa ko nagpakabit ng central locking & alarm 5.1k, pero marami na din dito sa tsikot avanza na nagpakabit sa labas mas mura kaya lang its your risk anything happen sa electrical wala ka ng warranty..pero mukhang oks naman. i pm mo si ownertype sya yung natandaan ko na nagpakabit kay jeff tan.
    Pwede pong malaman kung saang casa po kayo nagpakabit? At sino ang kontak nyo dun. Gusto ko rin sanang pakabitan ung Avanza 1.3J ko.
    Sep 2005
    #12627
    Quote Originally Posted by Deathbystereo View Post
    Mga Bossing magtatanung lang po sana, sino na po nakapag palit ng Fuel Filter ng Avanza nyo? kung san po sya located sa ilalim ba ng engine or sa Fuel Tank. kung Plastic ba or Metal, sana may magreply thanks.
    sir heto. sorry medyo malabo nga lang (camphone).
    nasa lower left sya pag nakaharap ka under the hood. yung may red circle. sensya na kung malabo.
    Dec 2007
    #12628
    Heto yung PDF, it's a good file to download, mas mabilis ang pag-search:
    http://www.kenwood-electronics.com.m...DPX-MP2090.pdf
    Nasagot na rin pala dati yung tanong mo dun sa kabilang thread, ma'am Jackie :
    Quote Originally Posted by chaolala View Post
    sir,
    tama, nasa manual nga.. hehe! <snipped> bukas ko nalang ulit ikabit yung cable..tinanggal ko ulit eh.. huhu! sa standby mode lang pla, tpos press menu ng ilang sec. until may lalabas na sub menu..tpos i down lng by pressing control knob..hanggang makita yung aux menu then press right to turn on..hehe! sana tumalab na 2m, nang pwede na magmit yung mga mp3 player or other gadges na pwede..hehe! maraming salamat mga sir..
    Aug 2005
    #12629
    Toyota Sparky:
    Before the Xenia and the Avanza, It was the 7-seater Sparky.
    Engine: K3-VE. Same engine as the Avanza J.
    Circa 2000 to 2002
    May 2009
    #12630
    Compared sa typical na sedan, mataas ang clearance ng avanza. mataas din ang lugar ng air intake at alternator. Kung tataasan ba, baka maging less stable ang body lalo na sa cornering.
    ang strutbars at stabilizer ay nakakatuling maging stiff ang body ng sasakyan. mas stiff less flexing so makakatulong sa body in the long run.
    *Sir Mel
    thanks for answering my queries.. one last question po.. installing this strutbar , stabilier and modifying fuel filter.. mavovoid po ba ang warranty ng avanza?
    Thanks po again.. more power sa Avanza club
    Aug 2005
    #12631
    Strut bar and stabilizer maybe no.
    Fuel filter modification?
    Air filter mod, maybe yes
    May 2009
    #12632
    thanks sir.. .. its air filter modification.
    ansarap pagandahin ang avanza... budget lng problema
    Aug 2005
    #12633
    Budget at senado.
    Hirap makakuha ng allocation para sa budget.
    hehehehehe
    #12634
    Quote Originally Posted by jscruz75 View Post
    sa toyota makati ako nagpakabit.yung contak ko dun yung SA ko, kaya lang nag abroad na daw nung huli ko syang hanapin dun sa show room. di ko lang sure kung same price pa sila, last january 2007 ko pa napakabit yung sa akin ang brand cobra, before ilabas ng casa kinabit na nila alarm wit key less entry.
    #12635
    thanks sir woohoo, i think we have a different manual but i will check it again, in case talagang wala dun sa manual, i follow ko yung instruction mo. :thanx:
    haaaluuuu AM BACK IN TOWN!!!
    wow active na active sa forum ang Ate Jackie....miss you na honey...will see you sa EB....di ko na kaya mag back read haba....
    btw...tanong ko lang kung sino na dito ang nagpa-repaint sa labas ng casa? my vanzie is silver...nahagip ng bwisit na owner malapit sa rear wheel nagchip yung paint....I would appreciate if you can give me name ng shop and contact person...TIA
    Sep 2005
    #12636
    mam jane.. sa Toyota North Edsa dalin mo.. 1,200 lang yan..
    #12637
    "mga sir.. tanong lang po.. medyo tagulan kasi ngayon .. how do you maintain your avanza ? lalo na sa mga nadadaan sa baha ? ok lang ba ng ground clearance po ng avanza?"
    ^^^ di kami nakakadaan sa baha, pero pag ganitong tag ulan wash/wax lang ginagawa namin. good thing may parking space ako sa building kaya di nababasa si vanzie. baka si shadow or ate jane makakasagot sa iyo.
    sowee for the late reply...anyway, bago pa mag tag-ulan I waxed na vanzie with NUFinish (advertisement na naman ito!) kaya ngayon tubig tubig na lang para di manikit dust....
    pag napadaan naman ako sa baha pina-pa underwash ko si Vanzie...Meron akong post paki-search na lang when I brought Vanzie to GTS at total underwash pati gulong tinanggal at nilinis buong ilalim...mas gusto ko yung underwash from GTS kesa sa gas station na binubugahan lang ng soap and water. HTH
    pag basa lang ang road ako na lang nag underwash kay vanzie.
    OK ang ground clearance ng Avanza ang route ko daily is from Balintawak --EDSA--MONUMENTO--SANGANDAAN. yung bandang puregold medyo malalim dyan magbaha.
    #12638
    ay oo nga pala nagpa repaint ka na.....thanks qwertz sa weekend try ko dumaan...or isasabay ko na lang sa PMS ko....kita kits sir
    #12639
    Hello po sa mga owners ng avanza, i need your advice, im looking for a 2nd hand car budget 380k-450k choosing between avanza j 1.3, or revo sr 2.o / adventure 2.0 gas.
    im considering to take the avanza, i wanna know why did you choose the avanza as well? what makes it your choice?
    sabi nila may tendency daw mag roll ang avanza at high speeds, what specific speed are they talking about, at 100kph o more than like 130-150kph?
    malakas pa ba ang 1.3? kahit puno ang avanza nyo with cargo? o na experience nyong hirap?
    how many persons have you tried to fit in a avanza? is it true the 3rd row seat is cramp?
    im planning to replace our family car (tamaraw fx '97 model) help po in making the decision thanks in advance
    Sep 2005
    #12640
    hmmm going around baguio.. i had 6 adults and 6 kids inside.. wala naman problema..
    about the 3rd row being cramped.. you'll find out na pag naka baba ang 3rd row.. mas maluwag pa leg room nang avanza kesa sa 3rd row nang Innova and Fortuner.
Toyota Avanza Owners &amp; Discussions [ARCHIVED]
