Page 629 of 749 FirstFirst ... 529579619625626627628629630631632633639679729 ... LastLast
Results 12,561 to 12,580 of 14970
    Jun 2009
    #12561
    dami n plang nbgo ngaun s avanza n j, tsaka ms mas mataas n cya ngaun!
    Aug 2005
    #12562
    Quote Originally Posted by aphrodzac View Post
    Iwas lang po sa SMS/Text speak. bawal po kasi.
    Mar 2007
    #12563
    ano ano mga changes sa 2009 avanza j model? substantial ba?
    Aug 2005
    #12564
    Quote Originally Posted by torresmd View Post
    Minor lang sa J.
    + corrugated roof
    + new instrument cluster
    + side VVTi emblems, none at the back
    Mayroon pa yata, kaso hindi ko na maalala.
    Sep 2005
    #12565
    gated shifter sa A/T
    Dec 2008
    #12566
    Share lang po experience pag-akyat Marcos hi-way sa BAguio City just lately.
    Very foggy situation and some roads under repair so di gaano maka-buwelo, past midnight time, and full of cargo loads back and third row portions. AC on 1 and 1.
    Sirs, shifting gear points ko sa rpm is from about 2.1 to 3. Ok lang ba ito?
    Di ko ito ginawa pero kung sa more than 3 ko magshift ng gear ok lang rin ba?
    Sa kennon road, 2 to 2.3 lang ang shifting gear points ko noon.
    Ask ko lang sa mga umaahon ng loaded, kasi baka nagbabago ang hatak ng avanza-1.3j. (which may be attributed to many things like gasoline used, fuel filters, etc.)
    tia again.
    Sep 2005
    #12567
    I remember nung si misis gumamit at ako pasahero, gulat na gulat ako kasi nag-change shift sya from 3-4K.
    baguhan pa kasi si misis. :D
    Oct 2007
    #12568
    Quote Originally Posted by manunulat View Post
    tia again.
    Noong umakyat ako sa Baguio via Naguillan using my Avanza J, 5 pax with roof rack full of stuff my RPM was 3k to 4k.
    Jun 2008
    #12569
    april umakyat kami ng bagyo 7 passengers (2 10 yrs old) loaded with roof rack shifting ko 4k.. 3rd gear minsan lang ako mag 4th. first time ko dinala avanza dun normal lang ba naka 3rd gear 3k rpm ako entering wide hairpin like turns? hehe
    Aug 2005
    #12570
    For best results pag paakyat, 2.5 to 3K minimum ang RPM. Not the best time to save gas. Bawi na lang sa pababa. Wag papayagan na less than 2.5K kasi delikado na mabitin.
    #12571
    Mga bossing, quick inquiry lang. My seat belt alarm is always blinking eventhough nakafasten na yung seat belt ko sa driver seat. Surprisingly its just started this morning nung iniwan ko si Scarlet simula last night sa labas ng house. Any suggestion to check? Thanks.
    Oct 2007
    #12572
    Quote Originally Posted by ece27295 View Post
    Baka nag loose yung terminal sa may driver seat malapit sa seat belt lock, may socket doon baka na disconnect lang
    Apr 2008
    #12573
    hi, im newbie here in forum, we planning to buy avanza this week we still undicided which one to pick either avanza or yaris, hope someone can help us to decide. hindi ba sirain ang avanza para kasing tinipid sa mga parts, hindi ba mabilis tumaob ang unit para rin kasing slim ang body lalo na sa biglang curved na street & flyover. thanks
    Aug 2005
    #12574
    Quote Originally Posted by mick25 View Post
    Sedans with a lower center of gravity tends to be mode stable than those with higher center of gravity. So far, wala pa naman akong nabalitaan na tumaob na avanza.
    Sa dulo ng C5 entering SLEX, i take the inner lane at 60kph. Hindi naman nakakatakot. actually now i do the curve at 80kph. mayroon na kasing rear stabilizer. :D
    Next month, 2 year old na avanza ko, iyong iba sa avanza club ay almost 3. so far wala pa naman major problem.
    IMO, the yaris is a good car for single persons kasi maliit lang siya and medyo masikip sa 2nd row. ang avanza is an small MPV basically.
    Apr 2008
    #12575
    thank you sa advice, kamusta naman po gas consumption? matipid ba? sorry hindi na ako nakabasa dito sa forum mabagal connection ng internet ko so i write my inquiries here
    Aug 2005
    #12576
    I get between 13 to 14 km per liter. mixed city and hiway. This is my running average for the past 11 months.
    Apr 2008
    #12577
    hi, saw your photobucket ask ko lang what problem couse ng air temperature? nasira ba?
    Apr 2009
    #12578
    ^^^ OT lang I like your avatar, meron bang medallion na ganyan kasi name ko naka engrave dyan.
    My vanC is 5month old na, pero wala pa kami nakikitang problema. One time punta kami sa macapagal, nagkasya 10 na tao kasama driver, plus isang infant at 4 na toddlers. Sa akin mas convinient ang avanza kesa sa sedan. dami mo pwede isakay lalo na kung long drive or pasyalan time.
    Aug 2005
    #12579
    To replace the spark plugs, the air filter box has to be removed. This might have damaged the wire connecting to the MAF sensor. Just a quick soldering job and it is now OK. Free repair, using the warranty.
    Oct 2007
    #12580
    It depends on your requirement, if you don't need a 7 seater utility and versatile car then Yaris is just right for you. I remember when I had just one kid my car was a hatchback lang (Charade) because I dont need a big car that time and to save gas either. The space of my hatchback was just enough for my stuff. But then when my family began to grow my preference changed. I changed my car into a sedan. Now I already have 3 kids so I need larger car, my preference changed from sedan into an AUV/MPV and now even SUV. If my family continues to grow then I will change my car to Van, then If it still grows a Coaster, then bus...etc just kidding
