Page 598 of 749 FirstFirst ... 498548588594595596597598599600601602608648698 ... LastLast
Results 11,941 to 11,960 of 14970
    #11941
    mayroon akong nilagay sa mga salamin ko na parang water proofing para mag bead then roll down kaagad ang water droplet. Konting punas lang sa salamin any ok na.
    iyon lang nga hindi nahahamugan ang avanza ko. may garahe kasi. :D
    press anong brand ito? para ma try
    Sep 2005
    #11942
    Quote Originally Posted by jayemkay View Post
    greetings tsikoteers!
    again, sorry to butt in pero need to bump up this mini-discussion here since it arose my interest. Just wanted to inquire with sir jujoe and sir medelson regarding the powerlocks and alarm installation. I recently got my Vanzy J from TYT Alabang and balak ko sana pakabit ng door locks (safety first syempre) but as per CASA, hindi pwde locks lang, kelang meron kasama alarm, hence, 9.5K ang damage, as opposed to roughly 4K kung sa labas papakabit. I'm also worried about my warranty, pero since i read your posts na mas mura pala sa ibang TYT, i wanted to try them out.
    * Sir Medelson, magkano po damage para sa locks and alarms sa TYT Ortigas?
    * Sir Jujoe, nakapag pakabit na po ba kayo ng alarm and locks? where and how much did you spend?
    Any inputs or info from you or any other tsikoteers here would be MOST appreicated!
    Cheers!
    kung malapit ka sa tyt OTIS, doon ako nagpakabit ng alarm with centralized locks. 6k inabot sama na kabit. thunder yung brand. oks naman hanggang ngayon.
    btw, samahan mo na rin ng courtesy door switches (2pcs) para sa rear doors mo. nasa 500+ sya, 2pcs na.
    hth
    Sep 2005
    #11943
    Quote Originally Posted by jujoe View Post
    gamit ko rain away and rain clear. oks naman sya.
    medyo di ko ginagamit ngayon kasi mag-summer na.
    #11944
    Mga Sirs, help naman sa water stain? adhesive stain? sa salamin ko. Pag basa lumalabas ito, sa umaga pag mahamog, kaya dapat tuyo lagi ang salamin ko para hinde kita. medyo hasel pag umuulan.
    sa rubbing compount nabawasan ng konti.
    kinuskos ko ng kamay ko nabawasan ng konti
    TIA
    [IMG]file:///W:/DCIM/100CANON/IMG_0529.JPG[/IMG][IMG]file:///W:/DCIM/100CANON/IMG_0529.JPG[/IMG][IMG]file:///W:/DCIM/100CANON/IMG_0529.JPG[/IMG]
    hello... pwede mo sigurong subukan yung Elevo Water Mark Remover. php279 ang bili ko sa Concorde. brgds.
    Sep 2005
    #11945
    or dalhin mo sa big berts.. 350 yata windshield polishing nila.. tanggal yang watermarks don..
    Aug 2005
    #11946
    Quote Originally Posted by woohoo View Post
    Pres, mas helpful siguro kay jujoe kung sabihin mo kung ano iyung nilagay mo.
    Check ko mamaya pag uwi ko.
    May 2007
    #11947
    Quote Originally Posted by puroy View Post
    hth
    sakin from TYT Balintawak 7500 central lock and alarm (AVT)...nung una okay naman working perfectly...now my times na biglang nag-aalarm pero for 3 seconds lang siguro. Baka naging sensitive na yung sensor..or my nagalaw yung mga gumawa sa casa ng magpa-15k check up ako
    Dec 2008
    #11948
    Quote Originally Posted by ownertype View Post
    i still have 3 spare hubcaps. Nabenta ko na yung isa. Nilalako ko siya sa mga nawalan/nanakawan ng hubcaps. Di ko alam na may nilabas sila unit na wala hubcaps.
    Mga sirs, anyone else here yet selling their stock hubcaps for avanza j?
    Need one more.
    #11949
    Quote Originally Posted by nencila View Post
    gud am! tawagan mo si ice member din natin un sister sya ni werty, d2 sya sa bdo grinhills dun insured vanzy namin. eto #09157629415
    Thank you for the information. ill try to call him.
    Dec 2007
    #11950
    hth
    Many thanks for the heads up and tips, sir puroy. mukhang sa inyo pinaka mura so far na CASA, i hope your purchase was recently. i inquired with TYT Bicutan, 7k daw. Sa TYT shaw, a whopping 10k kung walang ibang mag post na cheaper, i might just make the long trip to OTIS.
    Quote Originally Posted by boyitlog View Post
    sir boyitlog (that didn't sound quite right) thanks din po sa inputs. Sayang talaga ung sa Goldrich ni Sir Jujoe, mukhang ni-sacrifice nya talaga ung warranty, or baka tapus na ung warranty nya.
    p.s.
    to the tsikot mods, please help with my quadruple posts, pa delete nalang, sensha na.
    #11951
    sacrifice na talaga ako, waranty pa ako sir.
    CASA estimate cost ng alarm & powerlocks is P9k, gold rich P3400. just being practical.
    #11952
    Quote Originally Posted by pourice View Post
    Salamat sir, will try that.
    san concorde kayo nakabili?
    #11953
    sa SouthMall, sir. pero malamang available sa ibang Concorde branches yan, tulad siguro ng sa MegaMall.
    #11954
    hello mon here!
    Sep 2005
    #11955
    welcome to the Avanza club mon!
    Oct 2008
    #11956
    I noticed that the number 3 fan (front aircon) of the avanza is very loud compared to number 2.
    Will using number 3 in the long run will have detrimental effect to the fan system?
    Because sometimes in short ride, I prefer not to use aircon with window closed to avoid pollution, so I use the blower only.
    Oct 2008
    #11957
    Oct 2008
    #11958
    #11959
    Quote Originally Posted by dukedentist View Post
    hello mon here!
    hi po! kayo po ba yung sinabi ni jasp na nakasalubong ko? beep beep beep po!!! member na po ba kayo ACP?
    Dec 2007
    #11960
    Quote Originally Posted by yagami_kira View Post
    The only detrimental effect to the fans is the faster wear because of higher spinning speed. Parang deskfan or standfan lang iyan. Mas mabilis masira kung laging nasa highest speed setting.
    Me, I use #3 setting only after starting the engine, and before turning it off.
    HTH...
