Summer is officially here! Honda Cars Philippines, Inc. imparts practical tips on proper use and maintenance of car air-conditioning unit to beat the summer heat. The air-conditioning unit is an indispensable item in today’s car especially in a tropical country such as ours.
In new cars, problems hardly ever occur but after a length of time, depending on the working conditions, its efficiency naturally diminishes. So, it is advisable that car owners know how to properly use and maintain the car’s air-con system in order to obtain the longest possible service.
Here are the following suggestions:
1 Check the position of the compressor control switch (A/C knob) if it is in the ‘open’ or ‘shut off’ position. One should shut if off before starting the engine. This will avoid unnecessary drag caused by the compressor while cranking the engine.
2 Once the engine runs on, switch the fan on first. Blow the air-con’s fan at the highest speed for about a minute in order to clear away the hot air trapped in the air-con’s ducts. Then, depress the A/C knob to turn the compressor on at coolest temperature. The next step is to adjust the fan speed and temperature control switch to the level most comfortable to you.
3 Switch off the compressor before cutting off the engine. Keep the fan on at highest speed so that it blows away all humidity trapped inside the evaporator or ‘air-box.’ This will help eliminate the smell of stale air when you subsequently turn on air-con again, and at the same time, to lengthen the service of the evaporator. The process only takes about 2-3 minutes.
