Results 1 to 10 of 12
- Jan 2006
- 4
January 16th, 2006 04:47 PM #1i have a revo glx 2002. my problem is regarding the loud squeaking noise heard from one the pulleys especially when i turn on the aircon.your help is highly appreciated.thanks in advance!
January 16th, 2006 05:31 PM #2
tensioner pulley ng aircon malamang, sira na bearing. mura lang yan pare ko at madali lang palitan, palitan mo na bago masira ng husto at compressor drive belt e maputol. eto yung nagte-tension dun sa aircon compressor belt.
January 16th, 2006 05:38 PM #3
sir try nyo din ang check ang condition ng belt or
check nyo rin ang tension ng belt baka mejo maluwag lang sia ...IMO
- Jan 2006
- 4
January 18th, 2006 12:11 PM #5
try mo muna lagyan ng konting grasa yung GILID ng aircon belt.. maraming ganyan na revo hehe..
ang cause nyan eh dahil nababasa either sa car wash or splash from ilalim,
yung sa amin din nag-squeak na, dati grasa nilalagay ko, gamit ko ngayon eh yung "belt conditioner" .. good for 1 month at balik squeak na naman dahil natuyo.. pero parang meron thread dito sa tsikot na nagsasabi na lulutong daw yung belt...
kung pulley talaga, pa-check na sa aircon shops..
January 18th, 2006 01:29 PM #6
Originally Posted by tamaraw
- Jan 2006
- 4
January 19th, 2006 05:06 PM #7thank u mga sirs! papacheck ko na lang yung belt.baka for replacement na sya.BTW 49K+ na yung takbo ng revo ko.
January 19th, 2006 05:44 PM #8
sakin din sir ganyan...everytime na naka on ang a.c. may pasulpot sulpot na ingay lalo na when steering to the left and right...ilang beses ko na pinahigpitan yung belt pero nandun paren. i don't hear the squeak if not using the a.c. changed the 2 belts na (ps and ac). tried putting belt conditioner naren nandun paren ang squeak
pinacheck ko na ke mang mario, tanggal lahat ng belt, check nya yung pulleys, ok naman daw...gano po ba dapat karami ang pagspray ng conditioner? liberal ba as in the entire belt? mejo conservative kase yung pag lagay ko eh...
TIA!
February 2nd, 2006 05:17 AM #9
WD40 lang yan tol ok na & check da belt maluwag lang yan.... dont need to go to shop u can DIY............
Toyota is my choice
- Aug 2005
- 2,063
February 2nd, 2006 08:35 PM #10baka maluwag lng yun compressor belt ng aircon mo/ or need to be repalce / the pulley is maluwag /sira na bearing sa loob ng compressor.
i have a theory, if the oil filter is not primed (filed up prior to installation), the initial...
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
