Results 1 to 10 of 23
- Jul 2010
- 166
July 18th, 2015 06:16 PM #12e engine po, bagong overhaul, bagong karburador. Pero bakit po ganon? Pumupugak po yung tambutso, inadjust na rin po yung timing at a/f mixture. Ano po kya problema? Sa muffler na kya? Ramdam ko po kasi pag naka upo ako da loob ng kotse at sa steering at accelerator yung pag pugak ng tambutso. Patulong naman po
July 18th, 2015 07:21 PM #2
Misfire[emoji1]Baka hindi kailangan ng overhaul nadagdagan tuloy ng problima. Hola hola Hawaiian mechanic
- Oct 2009
- 2,271
July 18th, 2015 07:49 PM #3
July 18th, 2015 07:57 PM #4
Questions:
1 was it " pugaking" before the overhaul?
2 what do you feel- vibration? Noise? Loss of power?
3 is the symptom random or does it have a pattern?
4 when does it happen? With engine warm or cold?
5 if you place a strip of paper like peso bill at the end of the tail pipe, does the paper get sucked in periodically?
6 does it smell like unburnt fuel at the tail pipe?
- Jul 2010
- 166
- Jul 2010
- 166
July 18th, 2015 08:12 PM #7
A smoking engine does not necessarily dictate an overhaul, it might have been bad valve stem seals. Next time before giving way to an overhaul hungry mechanic, have cylinder leakage test and compression test done first. Compression test while cranking and engine running compression test usually determines if an engine tear down is necessary
- Jul 2010
- 166
July 18th, 2015 08:15 PM #8Sir jick.cejoco. before and after inoverhaul ganon pa rin po pugak, nafeel ko po sa vibration, random po sya. Mas malakas po pugak pag bagong start. Try ko po bukas yung sa papel. Matapang po yung amoy ng usok. Pag binuksan po pinto malakas amoy lalo na pag naka aircon.
July 18th, 2015 08:22 PM #9
Your misfire can either be caused by mechanical problem but since you mentioned it has been recently "overhauled" you can rule this out if it was done right or ignition misfire. Check your ignition wires, plugs and distributor cap. So the overhaul did not fix the symptom, it got worse for a fee?
- Jul 2010
- 166
July 21st, 2015 12:09 AM #10
I want to be clear that I'm mainly against just putting in water (deionized, distilled, or tap -...
Coolant...
