Results 31 to 34 of 34
- Apr 2014
- 6
April 24th, 2014 10:55 AM #31
- Jun 2015
- 1
June 2nd, 2015 01:19 PM #32
- Mar 2016
- 1
March 31st, 2016 11:13 AM #33Hello tanong ko lang po kasi yung vios 2011 nag umpisa sya ng hindi nag start sabi ng mekaniko fuel pump pinalitan ng hindi original. Ok naman sya oneclick lang sya pag start sa umaga pero pag napahinga sya ng mga 1hour yung first start nya parang naghihingalo pero sa second start kumakagat naman sya, after 3days ayaw ng mag start, ginawa ng mekaniko meron lang sya ginalaw na wire sa fuel pump nag start na sabi nya wiring nag rewire sya ng isang wire dinirekta nya sa ignition pero ganun parin after 1day lang pinatingin ko uli sa ibang mekaniko fuel pump na naman daw pinalitan nya ng ibang fuel pump malakas daw yun pang nissan nag alala ako, sa ngayon ayaw ng umandar malakas daw masyado yung fuel pump check namin bagong spark plug sunog at basa yung dating mekaniko ko sabi yung camshaft sensor daw. Lalong nasira lang kotse ko. Pls help ano kaya problema sa vios ko na dati ang ganda naman ng andar. Btw second hand ko sya nabili after 1yr lang sya nagloko. Plano ko dalhin sa casa na mapaandar lang. Nagtanong ako sa toyota 14k plus yung fuel pump nila at diagnose daw ay 2.900. Pls help po.
March 31st, 2016 01:55 PM #34
Clean the plugs and go and buy the proper fuel pump. The injector duty cycle is programmed based on an assumed rail pressure that will be different if you use different fuel pumps. This is why the plugs got wet when you placed the new pump.
The general running problems can be caused by many factors, probably best you go to a shop with an OBD reader and have them check everything first before buying anything else.
Very sad... horrid, even. In the news, 2 fatalities na and among them, a 5 y/o girl. It's odd...
