Results 21 to 30 of 44
- 54,251
July 1st, 2017 06:32 PM #21errr.. did you buy the car by mail-order? with all due respect, you should have inspected it first.
-some freshly installed belt systems might need some bedding-in; it is normal to have it re-adjusted after a few km. but i believe the altis is a serpentine belt... the squeal might not be the belt. it might be an idler bearing.
-the power window can be repaired. 2K siguro, by personal experience. hindi na ako nag-haggle, e.
-fix or change the trunk cable.
-have the thermostat and fan restored to factory spec. it's not that expensive.
all in all, all those above will probably cost considerably less than the lawyer's acceptance fee.Last edited by dr. d; July 1st, 2017 at 06:45 PM.
- May 2017
- 22
July 1st, 2017 06:38 PM #22
- May 2017
- 22
July 1st, 2017 06:41 PM #23Ininspect naman po namen. Ung sa belt po sir nung chineck namen okay naman siya. Noticable lang po ung sound kapag po sstart mo for the first time lets say within the day ung kotse. First few minutes lang po tapos kapag nakaandar kana mawawala din. Tapos if pinark mo man sa mall tapos binalikan mo at inistart, wala ung sound. Pero if matagal ng di nagrun ung makina tapos binuksan mo ulet, maririnig mo po ung squeal. Di namen nakita agad un nung chineck namen ung kotse kase ginamit po nila nun e, so nag run na ung makina. Sana may sense sinabi ko sa inyo.
- 54,251
July 1st, 2017 06:46 PM #24
- 54,251
July 1st, 2017 06:49 PM #25barring catastrophic catastrophy, all these can be easily repaired.
prepare 15K. may pang-kfc na yan.
i was about to suggest an excursion to banawe, QC. but i see you are from out of town...
nevertheless, drive out of the house by sun-up and go to banawe in QC, with moolah. i am confident, hindi a-abutin yan ng 1/2 day. when i brought my altis there, i was pleasantly surprised at the plentiful of knowledgeable mechanics, and availability and cheap cost of parts. choose a shop with its own parking space.
but BE WARNED. there are many glib salesmen there. be sure you do only what you set out to do.
err... no. i am not in any way connected to toyota.Last edited by dr. d; July 1st, 2017 at 06:57 PM.
- May 2017
- 22
July 1st, 2017 06:55 PM #26
Sir, maraming salamat po. Kahit sobrang naiinis at nalulungkot ako sa nangyari medyo gumagaan pakiramdam ko dahil sa mga comment at tulong/suggestions niyo. Sobrang thank you! ngaun po pinagiisipan ko mabuti kung anong magandang gawin if ibebenta ko ba siya or hindi. I don't mind losing 10-15k nung price na binayad ko, basta makuha ko lang siguro ung most ng naipon ko. Pinaghirapan ko po kase un. 25 years old lang po ako and baguhan lang sa kotse, pangarap ko lang talaga magkakotse kaya bumili ako.
About po sa squeal na naririnig ko, iniisip ko rin po pano ko maipapagawa un. Hindi ko po kase marereplicate ung issue kapag dinala ko sa shop kase umandar na ung makina pag dating ko dun e, kapag inistart dun wala ng maririnig na sound. Not unless iwan ko muna dun for few hours siguro tapos start ko ulet.
About sa power window and cable sa likod, di ko po masyadong pansin un.
Yung fan po, di po ba pwedeng pabayaan nalang siyang ganyan? Or mas advisable po talaga na naka connect sa thermostat?
- May 2017
- 22
July 1st, 2017 06:57 PM #27
- 54,251
- 54,251
July 1st, 2017 07:02 PM #29
- May 2017
- 22
July 1st, 2017 07:12 PM #30Thank you po! I wish same po tayo ng mentality. Puro kase anxiety nararamdaman ko po ngaun. Pero maraming salamat po talaga! Sobra! Gawin ko po mga advice niyo. I salute you sir. Thank you!
Sana po masarap tulog niyo araw-araw. Isipin niyo nalang po nakatulong kayo ng isang tao ng tumayo after nadapa kahit ayaw na nyang tumayo. Haha. Medyo OA man pero nalulungkot kase talaga ako sa nangyare, ngayon lang ako nakaranas ng panloloko. Anyway, I'll make sure to pay the favor forward sa kung sino man matutulungan ko personally at kahit hindi man dito. Salamat po!
Well looks like they're gonna make it easier na to transfer ownership. Timely since I need to...
transfer of ownership / registration cost
