Page 11 of 12 FirstFirst ... 789101112 LastLast
Results 201 to 220 of 1627
    Dec 2013
    Quote Originally Posted by vvti2.0 View Post
    Chances are nabaha yang unit mo. Iparegprogram mo yung ecu mo na pang manual.
    Sir May alam ba kayo kung saan ko pwede ipa reprogram ung ECU automatic to Manual? Salamat sir
    Dec 2013
    Sir may idea po ba kayo kung saan nagpapa convert ng ecu automatic to manual at magkano po kaya sir? salamat
    Dec 2007
    Saw a black Fortuner with plate ZPP xxx this morning. At 30 kph, it was spewing thick black smoke worse than the jeepney that was running beside it.
    Jan 2014
    The secret of cars longetivity is following scheduled maintenance. Have two fortuner 2.5 2008 and 3.0 2013 but never had any problem for the first with mileage of 100K and that's the reason to buy a second one. Also any early sign of problem like emitting black smoke must be attended earlier. You can see only few old SUV of this type with that black smoke but I think those owner is saving for maintenance.
    Sent from my iPad using Tsikot Forums
    Dec 2007
    Quote Originally Posted by navnav View Post
    I have a friend with a 6 year old V Fort. It has 160K on the odo. But he is in Thailand. He has no problem whatsoever and has already brought the car to Australia. He does the basic maintenance himself and regularly changes the oil at 5K. I consider him an engine expert and he only follows standard maintenance practice.
    Apr 2014
    1000% agree to this. all cars whatever make and model, gas, diesel, lpg, hybrid, they need to be maintained ....
    if ayaw ninyo ipagawa sa casa for whatever reason. then buklatin ang owner manual nandun malinaw nakalagay maintenance schedule at sundan ninyo po ...
    kaya mausok ang diesel, may busted na sa fuel system. most probable may injector na sira na. mahal ang CRDI system base sa sabi sa akin ang isang oem diesel injector ng toyota 2kd-ftv (innova, hilux, fortuner) is php 95K!! multiply ninyo pag lahat ng apat na injectors nasira
    for diesel.... pakarga sa mapagkakatiwalaang gas station hindi lang kung saan malapit o mura. at eto lang ang pinagkaiba, change fuel filter earlier depending sa fuel quality nabibili mo (some fortuner club member change it every 10Tkm at trust me sa mga pinopost nilang pics sa forum grabe na ng dumi ng fuel filter sa ganung kaaga, eh ang factory rating ay 40Tkm)
    Aug 2005
    Quote Originally Posted by ment View Post
    Di naman po 95k ang injector...nasa 28k the time I asked...2 injectors of my innova had abnormal readings, pina rebuild ko na lang sa central diesel. It cost me mga 12,500 per injector tapos labor nasa 33k all in all...
    Aug 2014
    Tnx bro...
    Aug 2015
    Mga sir, is the 2015 innova still a good buy? Has the d4d engine been perfected at this stage? coz i believe the new model with new engine will be launched by 1st qrtr next year. Thanks
    Jun 2012
    Quote Originally Posted by Sethdaniel View Post
    Perfect na. Good buy pa rin ang innova. Yun lang, next year mukhang luma na innova mo kasi may bago na
    Jan 2009
    I think that the current Innova has reached the peak of its maturity and most, if not all of the kinks that were discovered in the last 9 years have been corrected.
    I also considered waiting for the new 2016 model but decided against it. Usually, there's almost always some problems associated with the first "all-new" models. Couple that with a higher price tag of the upcoming model, I decided to get the current 2.5D A/T Innova G... and just look the other way when the 2016 model comes out. :D
    yes, it is still a good product.
    but waiting for the new model is a gamble.. sometimes, the outgoing model is prefered by some users over the incoming model..
    isa lang naman ang pintas ko sa current innova... the wider turning circle.. our neighborhood has narrow streets..
    Apr 2012
    Hiace fuel filter after 21k kms
    when we were young and poor-ish...
    "...puede pa yan! malinis pa naman yung itaas na parte.."
    Apr 2012
    He he. Ibang iba yung takbo after i changed
    Feb 2018
    hi po. ung innova ko bigla lumalabas engine light tas pag pinatay ko makina
    .. marereset sya tas mwawala. engine scanning mejo magulo. una lumabas throttle problem. wala nman nakitang problema. nag carb cleaner kami lag scan nawala na ung throttle error. pero ganun pa rin sya.. nag dedelay ang palo ng meter kahit nakatapak na ko. tas lumalabas pa rin engine light. ano tingin nyo mga boss?
    Sent from my Redmi Note 4 using Tapatalk
    dirty fuel...
    Feb 2018
    dirty fuel...
    palit po filter?
    you can start with that if hindi pa napalitan...
    Feb 2018
    ok thanks po [emoji5]
List of Toyota D4D Probems (Choking, Hard Starting, etc.)
