Page 161 of 163 FirstFirst ... 61111151157158159160161162163 LastLast
Results 1,601 to 1,610 of 1628
    Jan 2009
    #1601
    Quote Originally Posted by Sethdaniel View Post
    Mga sir, is the 2015 innova still a good buy? Has the d4d engine been perfected at this stage? coz i believe the new model with new engine will be launched by 1st qrtr next year. Thanks
    I think that the current Innova has reached the peak of its maturity and most, if not all of the kinks that were discovered in the last 9 years have been corrected.
    I also considered waiting for the new 2016 model but decided against it. Usually, there's almost always some problems associated with the first "all-new" models. Couple that with a higher price tag of the upcoming model, I decided to get the current 2.5D A/T Innova G... and just look the other way when the 2016 model comes out. :D
    #1602
    yes, it is still a good product.
    but waiting for the new model is a gamble.. sometimes, the outgoing model is prefered by some users over the incoming model..
    isa lang naman ang pintas ko sa current innova... the wider turning circle.. our neighborhood has narrow streets..
    Aug 2005
    #1603
    Quote Originally Posted by ment View Post
    1000% agree to this. all cars whatever make and model, gas, diesel, lpg, hybrid, they need to be maintained ....
    if ayaw ninyo ipagawa sa casa for whatever reason. then buklatin ang owner manual nandun malinaw nakalagay maintenance schedule at sundan ninyo po ...
    kaya mausok ang diesel, may busted na sa fuel system. most probable may injector na sira na. mahal ang CRDI system base sa sabi sa akin ang isang oem diesel injector ng toyota 2kd-ftv (innova, hilux, fortuner) is php 95K!! multiply ninyo pag lahat ng apat na injectors nasira
    for diesel.... pakarga sa mapagkakatiwalaang gas station hindi lang kung saan malapit o mura. at eto lang ang pinagkaiba, change fuel filter earlier depending sa fuel quality nabibili mo (some fortuner club member change it every 10Tkm at trust me sa mga pinopost nilang pics sa forum grabe na ng dumi ng fuel filter sa ganung kaaga, eh ang factory rating ay 40Tkm)
    Di naman po 95k ang injector...nasa 28k the time I asked...2 injectors of my innova had abnormal readings, pina rebuild ko na lang sa central diesel. It cost me mga 12,500 per injector tapos labor nasa 33k all in all...
    #1604
    Quote Originally Posted by ersatz0906 View Post
    "the problem with the D4D isn't actually the engine itself, but more on the fuel filtering/delivery. madumi kasi ang diesel fuel natin dito, marami sediments, nagipon ang sediments at bumara sa filter, in turn, hindi umaabot sa engine ang diesel fuel. pinalitan na lahat ng filters sa assembly line, kaya lahat ng releases starting 2006, no problems na."
    From SA of Toyota Makati...they are a plant-owned dealership, sabi nya
    so sana post nyo rin what month and year did you purchase your D4D
    thanks
    i am confused..
    are we blaming the fuel or the filters?
    if it is the fuel, then why did the problem cease when the filters were replaced?
    i have one of the first batches 0f 2005. my filter warning light lighted up early on (water contamination daw). i replaced the filter myself, and it hasn't recurred since.
    wow! ancient na pala itong thread na ito..
    Apr 2012
    #1605
    Hiace fuel filter after 21k kms
    #1606
    when we were young and poor-ish...
    "...puede pa yan! malinis pa naman yung itaas na parte.."
    Apr 2012
    #1607
    He he. Ibang iba yung takbo after i changed
    #1608
    Yung 2005 hilux namin 2kd-ftv engine naka limit lang to 2800rpm. Kaya 110kph lang max kahit todo tapak sa accelerator pedal and naka warning light yung check engine. Paki recommend naman ng shop na magaling mag diagnose and repair. Central? Denso? Berima? Or other shops? Thanks sa sasagot
    Dec 2015
    #1609
    Help mga sir, naka-experience kasi ako na mag loss power at parang napuputol ung supply ng diesel ng innova dsl MT 2006 ko, minsan pag maalog sa daan namamatayan ako, pag naka aircon ako madalas magclog. pag hindi ako nka aircon madalang mag clog. nagpadiagnose ako sa toyota, need daw ibaba ang tank at cleaning, so pinababa ko na ang tank and line cleaning, change fuel filters, change oil narin, nagpalit nrin ako ng SCV pero kasamaang palad ganon parin..
    Dec 2015
    #1610
    Quote Originally Posted by innovavillas View Post
    hindi parin makita ng Toyota ang problema nung innova ko, wala kasi warning light. pinalitan nila ng ECU pero nandun parin ang problema. ask ko lang, may kinalaman kaya ang electrical wiring ? kapag ba biglang nawalan ng kuryente ang diesel engine, mamamatay ang makina? pasensya na po sa tanong, baguhan talaga ko sa mga sasakyan.
List of Toyota D4D Probems (Choking, Hard Starting, etc.)
