Results 1,591 to 1,600 of 1628
- Feb 2003
- 324
September 25th, 2014 10:09 AM #1591
October 1st, 2014 01:14 PM #1592
Sirs,
This can be removed by some Toyota casa and can be done DIY...
Just to share, here are the steps:
1. Remove / disconnect warning switch connector of fuel filter.
2. Turn ignition switch to "ON" position - never start.
3. After turning the ignition switch ON, connect the warning switch connector within 3 to 60 seconds.
4. Check that the combination meters filter warning lamp turns off.
5. In case the "Filter Lamp" does not turn off, try to remove first Negative terminal of battery for at least 1 minute and return, then perform items 1 - 4...
Hope this helps .... Tried and tested on our Fortuner and Innova...HTH
- Feb 2003
- 324
October 2nd, 2014 11:17 AM #1593
- Feb 2003
- 324
October 2nd, 2014 11:19 AM #1594
- Oct 2009
- 2
- 52,731
August 9th, 2015 09:00 AM #1596errr... which one?
some are truly wear and tear..
others can be argued..
and it's not only toyota.
errr... which one?
- Jul 2013
- 2,450
August 9th, 2015 09:21 AM #1597
- 52,731
August 9th, 2015 09:28 AM #1598
- Aug 2015
- 7
August 19th, 2015 12:10 PM #1599Mga sir, is the 2015 innova still a good buy? Has the d4d engine been perfected at this stage? coz i believe the new model with new engine will be launched by 1st qrtr next year. Thanks
- Jun 2012
- 4,448
August 19th, 2015 01:00 PM #1600
Daming issue ng SU7:grin:
Xiaomi E-Car
