Results 1,611 to 1,620 of 1628
- Dec 2015
- 10
January 22nd, 2016 01:30 PM #1611Problem Solved.. ok na innova ko, dinala ko sa Toyota San Fernando Pampanga and then after 2 days of diagnostics, nakita rin ang sira.. Faulty Integration Relay papuntang ECU - hindi sinabi sakin kung bakit nasira yung relay pero palagay ko electrical wiring problem, may nag-short siguro sa mga wiring kaya nasira ang Relay. they fixed the relay and the total cost is 3,500 labor only.
May 17th, 2016 11:50 PM #1612
i believe this thread was a continuation of what i started before. just to update you as i have been away for a while, TMP came up with a repair kit for the supply pump problem and it was all because of this....also, they took action on the list that i submitted and we are talking of hundreds of units affected before and after warranty lapse. they did a great job addressing the issue.
Pinoys with Toyotas worried over recalls - YouTube
- May 2016
- 3
May 22nd, 2016 01:08 AM #1613
- May 2016
- 3
May 22nd, 2016 01:16 AM #1614
- Aug 2008
- 45
November 6th, 2016 11:54 PM #1615This exact problem happened sa '06 Hiace D4D namin... pagka start, mamamatay siya after a few seconds unless apakan mo accelerator para di mamatay makina....
Toyota Commonwealth replaced the ECU... related raw sa warm-up idle circuit or module sa ecu... fortunately this was done under warranty before (1 year old pa lang Hiace namin then)... worth 40k raw yun sa invoice.
- Jun 2017
- 2
June 29th, 2017 08:47 AM #1616Any Hiace Commuter 2017 model whose owners detected the same problems?
- May 2012
- 129
July 12th, 2017 11:07 AM #1617Need HELP
Innova 2012 AT odo * 45k, last change oil wala pa 5k tinakbo around 4-5months ago
While on NLEX ako 120kph takbo ko tapos sinisubukan ko pa accelerate ayaw mag accelerate, kahit ano apak, then nag decelerate sya o babagal hanggang 80kph, then accelerate siya uli up to 120kph... Nagawa ko palang as suggested palit air filter, hindi ko pa nadadala sa mechanic
- Feb 2018
- 4
February 2nd, 2018 08:24 PM #1618hi po. ung innova ko bigla lumalabas engine light tas pag pinatay ko makina
.. marereset sya tas mwawala. engine scanning mejo magulo. una lumabas throttle problem. wala nman nakitang problema. nag carb cleaner kami lag scan nawala na ung throttle error. pero ganun pa rin sya.. nag dedelay ang palo ng meter kahit nakatapak na ko. tas lumalabas pa rin engine light. ano tingin nyo mga boss?
Sent from my Redmi Note 4 using Tapatalk
February 2nd, 2018 08:26 PM #1619
dirty fuel...
- Feb 2018
- 4
February 2nd, 2018 08:30 PM #1620
Daming issue ng SU7:grin:
Xiaomi E-Car
