Hybrid electric vehicles can be classified according to the way in which power is supplied to the drivetrain:
* In parallel hybrids, the ICE and the electric motor are both connected to the mechanical transmission and can simultaneously transmit power to drive the wheels, usually through a conventional transmission. Honda's Integrated Motor Assist (IMA) system as found in the Insight, Civic, Accord, as well as the GM Belted Alternator/Starter (BAS Hybrid) system found in the Chevrolet Malibu hybrids are examples of production parallel hybrids.[11] Current, commercialized parallel hybrids use a single, small (<20 kW) electric motor and small battery pack as the electric motor is not designed to be the sole source of motive power from launch. Parallel hybrids are also capable of regenerative braking and the internal combustion engine can also act a generator for supplemental recharging. Parallel hybrids are more efficient than comparable non-hybrid vehicles especially during urban stop-and-go conditions and at times during highway operation where the electric motor is permitted to contribute.[11]
In series hybrids, only the electric motor drives the drivetrain, and the ICE works as a generator to power the electric motor or to recharge the batteries. The battery pack can be recharged through regenerative braking or by the ICE. Series hybrids usually have a smaller combustion engine but a larger battery pack as compared to parallel hybrids, which makes them more expensive than parallels. This configuration makes series hybrids more efficient in city driving.[11] The Chevrolet Volt is a series plug-in hybrid, although GM prefers to describe the Volt as an electric vehicle equipped with a "range extending" gasoline powered ICE as a generator and therefore dubbed an "Extended Range Electric Vehicle"[12] or E-REV.[12][13][14]
* Power-split hybrids have the benefits of a combination of series and parallel characteristics. As a result, they are more efficient overall, because series hybrids tend to be more efficient at lower speeds and parallel tend to be more efficient at high speeds; however, the power-split hybrid is higher than a pure parallel.[11] Examples of power-split (referred to by some as "series-parallel") hybrid powertrains include current models of Ford, General Motors, Lexus, Nissan, and Toyota.[11][15]
