Results 1 to 10 of 23
- Dec 2008
- 105
December 29th, 2008 04:21 PM #1[SIZE=4]Hello Tsikoteers ![/SIZE]
I'm currently driving a corolla xl year 2000 model. Odo is around 80t kms or so. Recently had an oil change and the oil used was valvoline 20w-50 mineral oil.
Question is ... is this the correct grade / viscosity for my car ? I'm currently experiencing difficult cold starts. Car idle is ok during startup (while cold) but vibrates more upon reaching normal temp.
Should I be using synthetic ?? How about the grade ? 10w-40 ? 10w-30 ? Any experiences / suggestions ?
Thanks in advance ! [SIZE=4]Happy new year to all ![/SIZE]
- Nov 2008
- 81
December 30th, 2008 08:55 AM #2hi, if you still hav the manual check the recommended oil for your engine otherwise call toyota and inquire what is best to use. synthetic is good which is supposed to be used if you do not want to chnge your oil less frequently but if you sick to every 5000 km change then it should be alright. the vubration in your engine considering that it is already 8 years old can be caused by the transmission support bushing or engine support bushings. have it checked. regards
December 31st, 2008 12:25 AM #3
The 20W-50 should be quite fine. Just keep changing at 5000kms; using synth and extending your drain intervals wouldnt be too adviseable given our hot, dusty and traffic driving conditions.
- Dec 2008
- 105
December 31st, 2008 07:51 AM #4
- Dec 2008
- 105
December 31st, 2008 07:55 AM #5
December 31st, 2008 08:33 AM #6
ano ba ang engine model?
kung 97-01 4AFE - moderate climate: 15w40 or alternative moderate climate: 15w40
kung 92-97 4AFE - moderate: 10w30 or alt: 10w40
imo, 20w50 is too heavy...
December 31st, 2008 02:53 PM #7
Per experience, the only main concern with using a "thinner" oil would be when your engine is already aged or high mileage as this would have more propensity to leak through worn seals/gaskets. Other then that, there's not much concern with using 10W-40 or even 0W-40. 0W-30 or 5W-30 can still be used also but isnt adviseable on the high mileage or "heavy use" vehicles.
December 31st, 2008 06:49 PM #8
- Feb 2008
- 903
December 31st, 2008 09:10 PM #9My car (Innova gas a/t G) is new, just had its 1k pms sa casa. The regular engine oil + filter costs me P 1,400 only. While if I had it full synthetic it would cost me P 5,200.00. Due to financial concerns, I intend to have a regular change oil every 5k pms with the regular oil (which I think is 20W-50) + new filter. Would this be ok? In other words, hindi ako magpakarga nang full synthetic dahil sa gastos. Ok lang kaya?
- Dec 2008
- 105
December 31st, 2008 10:30 PM #10
engine model is 2e. 1300cc. corolla 2000 lovelife model. I think it has the same engine as the corolla big body.
I was also thinking the 20w-50 might be too thick. If there's no major drawback, I think I'll try 5w-30 or 10w-30 on my next oil change.
If anybody here is using the same engine, I'd appreciate your feedback re which oil you tried and which oil you using now.
The CHAdeMO plug is definitely a concern. And yes, you are potentially purchasing old tech. In...
2021 Nissan Leaf
