Originally Posted by
dr. d
possibilities:
1. you have a leak. it may be hard to find, as there are many thingees around the engine that the leak can hide behind.. check also your overflow cannister for leak; it may be the cause of it all.
2. your auxiliary fans are sub-optimal. they may spin, but not fast enough... the air sucked in is not enough. or they may not spin at all.
3. your radiator is clogged, making cooling sub-optimal.
4. you have a crack in your engine block, or a blown head gasket.
5. etc.
have fun troubleshooting.
